Hirunner
Started by Bazzi, May 31, 2004, 09:00:27 AM
gotrocks
looks awesome man, glad to see you got it running
Bazzi
I am having problems with the hidraulic steering assistant???   I can´t remember what You guys call it.
the steering pump always makes this whining sound when I accelerate. and when I check the steering fluit container.The fluit is pink. with litle bubles in it. I have a over size container and I don´t have any leaks. some one told me that there is possibly a faulty  seal in the steering box that drags in air. but I am not sure that that is the problem.
NEED Help
crawlerdan
your power steering pump is burt up, replace that, should be not too expensive, your pink fluid is a sign of over heating, and the whine is a sighn of overheating and a bad pump
good luck foreign freind :beerchug:
Bazzi
#123
what is wrong with those pictures. This is from a ´92 x-cab. 2,4 efi with ifs
A friend of mine installed a adapter plate from marlin and had problems with his propeller shaft hitting it..... He filed off the adapter plate.
Bazzi
couble pics of my truck from this newby trip me and couble of my friends held for the local 4x4 club
Bazzi
gotrocks
how did those truxus do in the snow
gotrocks
oh and what can you tell me about that green FJ in the pictures.  Can you get any more pictures of it for me
CTENG in KS
Quote from: Bazzi on October 28, 2005, 05:59:10 AM
They are fuzzy?
Bazzi
updates...  A whole lot has been done mainly electrical stuff tho.... and some other inside the truck stuff. I yous found this threat again thought someone deleted it or something...
But on the down site my truck and me got hit by this tiny ford ka (traffic accident) and we haven´t fully recovered after that. I am fine but the truck isn´t.
After the accident these where the broken things in the truck.
broken diff
something terrible wrong with the rear t-case. first the shifting forks went all wrong I fixed that but now I have this grinding clicking sound.....
busted Cross in the drive shaft.
bent frame
bent housing
bent shocks
and lots of other bent stuff.
and probably more.
I have repaired
the housing.
I am not sure what I will do on the diff I will decide tomorrow. order a diff from marlin or local
I had the frame fixed  and the housing realigned
I am waiting for my full floating kit to arrive from Front Range offroad which I am really looking forward to
the truck is drive able but it has 5:29 in the rear and 5.71 in the front. so no wheeling....
updates soon
Bazzi
just a litle tease....
I have so litle time that I can´t follow it through.... Leaving for London in few hours........
what´s that doing on my rear housing????
b_ripper8
Oh la la. Someone is going full-float.
Bazzi
#133
damn it  has been long since I have posted... I haven´t had any time to do so much as clean my truck since I finished that full floater....
And this is how he punishes me....
went home and picked up my old bended one and cursed me for my stupidity off asking C.J to ship my parts with ups if I hadn´t I would had the nice new fj80 arms and had installed a new and stronger drag link.....
But when I came home finally after replacing the steering rod and cursing the hell out off it    :lipsrsealed: My pregnant wife says I have a surprise for you... It was to heavy for me so it´s in the trunk of my car..... I go out and grab the heavy b*std and put it inside without even looking at it.... and after couble of hours she asks me if I wound open it..... and tadamn.... The shipment from marlin  ;)   :yupyup:   and what a pretty sight. So many shiny things....
Fongs
uhhhhhhhh Bazzi
what a nice women
Bazzi
I spent the day in the garage. I was trying to find out what that squeaky sound was that I have been hearing ever since the truck got rear ended.  :suprised: and damn was I in for a suprice    :help: I am pretty sure I should sue someone. The garage that fixed my frame sure as hell dit a bad Job.  :shakehead: The beam in the frame that´s behind the transmission. (is the most important beam in my suspension)  had a crack in it. so I removed both my fuel sells so I could weld it up but then I noticed the beam was really bent forwards.... ripped from the frame on both sites and bent like a v only forwards.    :shakehead:  so my only solution was to remove it and so I dit.  :flamer: (it´s always so simply in my head.)  A friend of mine fixed made me a new propeller shaft so I could skip the double one that I had (one piece bolted to the frame) and  after working on it from 9 am this morning till just now 00:00 I am almost  :attention:  finished I just have to weld the brackets for the fuel tanks. damn all this work somebody is gonna pay for this.
Tomorrow I hopfully post up some pics I forgot the camera and my body simply hurts.   :red_eyes:
Bazzi
and by the way I love the full floater.... I ove you guys some installation pics
Bazzi
#137
well here are some of the pics I took last night
A litle to much light but you can see the crack if you look closely
removed bouth the fuel tanks
The beam after I ripped it from the frame
Bazzi
one of the pieces I had to make to fix the tracktion bar to the new beam
The new beam test fitted
Bazzi
lifting the back of the housing so that the pinion angle will be a litle bit lower....
something like that
hmmmmmmm
looks like I have been rolling in the dirt having fun
Bazzi
#140
heating the bracked for the second fuel tank so I can bend it a litle bit forwards.... (notice the winch hook, near the red dot on the tourch)
My  partner  when ever I was having a hard time  :rivers: burned my self or got hit with that  :soapbox: tracktion bar he came and comforted me.
Bazzi
#141
called it for the night was happy but burned, brused, cut, and swollen, and dirty.  My mom snapped that photo just before I hit the shower and heated home,  here is before. hmmm  better just have that as a link.
(some skin showned)
http://www.gemlingarnir.com/modules/coppermine/albums/bazzi/b%EDllinn/vi%F0ger%F0/normal_1RIMG0053%20%2820%29.jpg
and after
I don´t know what happened I have never burned so much before just from welding and cutting.  :flamer:
I don´t have my usual helment but damn
Bazzi
today I ditn´t take really many pictures.....
painted  the new stuff. and installed one of the tank.
will finish the rest after work tomorrow.
I don´t know why but suddenly desited to built me a pair of Búkkar? ? ? (missing the english word)
that was the general idea I don´t have a better jack than that and after I have put blocks between the jack and the housing for years.
This idea popped into my head.
Bazzi
and common give me some replyes I feel like I am the only one reading this
Quote from: Bazzi on October 15, 2006, 05:50:39 PM
:psss: jackstands bazzi
CTENG in KS
Well that doesn't bode well for my similarly set up link...better think about beefing up that srossmember a bit more.
Bazzi
Quote from: CTENG in KS on October 15, 2006, 06:21:25 PM
My truck got rear endet last winter and I am thinking about blaming this on that.... cause the center of the beam was bent forwards and when I removed it from the frame that crack was ovius..... But on the other hand with that setup the beam takes a lot of tvisting and I was always kinda scared of it.  I just hope that the new one is weldet enaugh and beeffed enaugh I really don´t have that many more options on beeffing it mere
CTENG in KS
That would explain it beong bent forward...acceleration would tend to bow it out toward the rear.  I am planning on a simple square-tube brace angled to the frame, I already beefed the outer chord of the I-beam the other day to hold the bracket for the link better.
Bazzi
That´s the same as I was thinking before I notised that crack but don´t forger the twisting forse as well.   :burnout:
CTENG in KS
I will counter act the moment on the beam by tying the brace directly into the bracket.  Do my beast to take the entire load linearly straight out to a braced frame mount for the square tube.
