Author Topic: Transfer Case Crossmember bolts and captive nuts  (Read 6972 times)
YotaJosh
  • Male Posts: 499
« on: Nov 19, 2007, 07:36:37 PM »
All 4 of the captive nuts inside of the frame for my crossmember are gone. I'm sure they are rattling around in the frame somewhere. I've been running it gently with the 2 outer bolts in place on either side.
I plan on getting a BudBuilt crossmember when I go dual cases, and since it bolts up in the stock location, I'm thinking I might need those captive nuts.
So, I need ideas or methods on how to fix it. My current thought is to use Nutserts, but I'm not sure if you can get them that big (BTW - what is the size and thread for those bolts?).
I know I have other options, like the nice FROR crossmember, and using Ubolts over the frame, but I want to use the factory mounts.
'79 Short Bed Pickup 4x4
'04 4Runner V8 Sport 4x2
  • Turtle Points: 2872
  • Male Posts: 8,707
are there any acess points near by? maybe you could weld them in
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
I just did the ubolts welded to my frame thingy worked great.
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
You can cut the inner wall of the frame away weld in new nuts and rebox the frame.
DAWGTOY
  • Turtle Points: 460
  • Male Posts: 212
  • aint too old & broke up to sit down yet
heres what i did. i found flange nuts (nuts with a washer made on them)
the right size. metric but i don't remember the size. i used a hole saw from
the bottom and drilled out the old nuts. (the hole saw has to be the size of
the flange on the new nut). then just welded in the new nuts. not a big deal
but worth the effort.
dawg
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
YotaJosh [OP]
  • Male Posts: 499
No access points, without cutting a hole. :sad2: I don't have a big enough welder to patch the hole, and it will still be tight in there to get a welder gun.
dawg
That's another idea I had. Glad to see someone else has tried it.
DeadlyPeace
  • Male Posts: 593
  • Member since Nov '07
  • HEAVILY medicated for your protection!
    • ToyotaOffRoad
What about doing the same thing that Dawg did but instead of drilling the hole the size of the flange, drill it just a little bigger then the nut size. Then cut some two slots straight across (like a crosshair) for welding to the flange. To get the nut inside slide the flange up through the slot and hold it into place with a longer bolt and weld it. This will let the flange have a little more support to hold on to then just the weld. Just another thought. I'm sure either way will work ok.
Never let people think you’re a horrible person and always keep the heart of a young child…
YotaJosh [OP]
  • Male Posts: 499
Your hole idea is probably what dawgtoy did. Only the flange was on the bottom of the frame, i.e. he never put the bolt inside the frame, just pushed it into the hole and welded around the flange. Then you'd have to use a washer on the outer bolts to compensate for the flange on the new nuts.
RN37DD
  • Male Posts: 742
  • Member since Apr '07
i just used a nut about the same size. weld a 1/4 inch bar on the side of the nut 2 or 3 inch long. fish it in with a wire over the hole and thread your bolt in. the bar keeps it from turning in the frame. :thumbs: BTW i think i used 7/16-14 bolts that have an 11/16 nut size, so it kind of matched the stock 17 mm nuts.
« Last Edit: Nov 20, 2007, 12:25:15 PM by rn37dd »
YotaJosh [OP]
  • Male Posts: 499
Cheap and effective. I like it :greengrin: :think:
The only concern I see is if I need to remove the crossmember, and then reinstall it, and I loose the nuts in the frame. I guess that's what magnets and mechanics wire is for. Also, if the bar breaks off while removing the bolt, I'd have to resort to cutting the bolts out.
RN37DD
  • Male Posts: 742
yeah mine were turning in the frame when i tried to remove them. i used vice grips and a hack saw to cut one off and the other i drilled the side of the nut and split it with a cold chisel. lucky the metal is pretty soft.
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
87 4Runner redo
YotaJosh [OP]
  • Male Posts: 499
This is what I'm going to do  :twocents: http://4xinnovations.com/pages/drive/crossmembers.htm
I'd love to do that. Unfortunately, 4XI doesn't seem to make much for the first gen trucks. Someone that lives close to him needs to donate their rig for prototyping.
RN37DD
  • Male Posts: 742
in the above where i had to cut the bolts off those were the stock bolts that the captive nuts had spun. the nuts i welded have never broke and I've removed them 3 times.. ya gotta love them l52's. my kid still freaks when i say I'm pulling the tranny again. :willynilly:
DeadlyPeace
  • Male Posts: 593
    • ToyotaOffRoad
From what I understand I think with Dawgs the flange is flush inside the metal of the frame so the crossmember would go flush to the frame. Where I was talking about the flange being inside the frame, but on top of the metal. Here's a rough drawing of what I mean.
That's a nice price for those t-case mounts to. I usually get those for $25 used. For an $10 for a new one would be great. Plus I like the design of it.
I like the crossmember too. I'm wanting to do something like that on my 73 I'm rebuilding.
Josh what about welding a  stud into the frame :dunno:
RN37DD
  • Male Posts: 742
last night i pulled the home made captive nut out. the bar i used was closer to 3/8 round stock.. 9mm to be exact, 2 inch long. and the nut was 11/16 outside threaded to 7/16-20. still looks good, but i think I'll paint it before i put it back in.
YotaJosh [OP]
  • Male Posts: 499
There's always that too.
Thanks for the info. When it comes time to deal with this, I think I'm going to try it. Seems to be easier, and less modification to the frame, which is what I was really after.
Oddmar
  • Turtle Points: 74
  • Male Posts: 402
  • Member since Aug '04
  • J3 Productions
Here is what i'm gonna do, i'll just fab up my own arms and rubber pad/ metal weld-on bracket on the inside of the frame rails.
http://frontrangeoffroadfab.com/nfoscomm/catalog/product_info.php?cPath=21&products_id=35&osCsid=f69a8160d58773d4690326bbc4414b7c
And before i install it, i'll make a 1:1 scale blueprint, so the next time i need one i can just cut it myself.
The United States Constitution © 1791. All Rights Reserved.
Only when i am finished will there be peace: The peace of an empty wind as it blows across a land strewn with the bones of my enemies.
there ya go
RN37DD
  • Male Posts: 742
i pained them before a put them back this time.
Last post Mar 24, 2005, 09:21:28 PM
by Marlin
Last post Feb 01, 2006, 04:10:38 PM
by CSAKing
Last post Mar 01, 2013, 07:06:37 PM
by PyroJoe
Last post May 24, 2013, 11:06:00 AM
by 84toyota
Last post May 04, 2017, 07:16:45 AM
by cporche
