Transfer Case Bolts: Hardware Store Source?
Started by wrenchtech, March 24, 2005, 09:01:30 AM
wrenchtech
My t-case and transmission came to me as two pieces, but no bolts to connect them. Can I use common metric hex head bolts or do they need to be classified (grade) type? -- Matt
1999 4runner SR5, 3.4, auto, Horizon Blue
BLACKDOG
I would guess you would want to use grade 8 bolts, but most hardware stores do have them
              -Ronald Reagan
Marlin
You need six 10 x 1.25 mm fine thread bolts.
Being at home, I am not sure about the length. I would guess around 50 mm long.
Where are you located?
We will give you 6 new bolts if you pay the UPS cost.
Please give us a call at the shop in the AM.
Marlin
Marlin
The rear t-case housing has 7 bolts, and are exactly what you need.
Remove one of these bolts, and get 6 more just like them, or give us a call.
Sacramento is only one day away with UPS.
