Author Topic: v6 third in a 4cyl housing  (Read 2459 times)
diggs
  • Member since Nov '07
« on: Nov 12, 2007, 11:22:51 PM »
I've seen a couple of posts on this, but I couldn't find the definitive answer to help me spend the money.  I want know if I get the assembled v6 diff with the ARB and 5.29 gears, if it will fit in my 4cyl housing, or if I'll need to do any modifcation.  Is there any benefit to getting the v6 diff anyway?  Thanks in advance!
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
Re: v6 third in a 4cyl housing
« Reply #1 on: Nov 13, 2007, 06:02:02 AM »
Bolt in, you will have to widen and deepen the gear slots on the housing.
« Last Edit: Nov 13, 2007, 06:08:03 AM by OOPS »
Bcarlson
  • Member since Oct '07
« Reply #2 on: Nov 17, 2007, 06:39:50 AM »
Are the slots needed due to the 5:29's? Do the axle splines match?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #3 on: Nov 17, 2007, 07:35:31 AM »
axle splines  are the same ,   and yes  i think the 5.29 gears are  a little thicker :thumbs:
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #4 on: Nov 17, 2007, 11:50:48 AM »
Sometimes you can feed the ring gear through by turning the pinon as you insert the 3rd. It depends on the actual ring size and 5.29's will be tight depending on the manufacturer. Most of the time it is easier just to cut the notch out a little more just don't get too crazy though or you could end up with a leak.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
« Reply #5 on: Nov 17, 2007, 02:35:15 PM »
:dunno: my V6 4.88 3rd fell in nicely.
the bearings are larger in the V6, and the case has more ribs that are thicker.  The case will not deflect as much as a 4cyl version.
Last post Jan 07, 2005, 07:26:17 AM
by To The Floor
Last post Feb 28, 2005, 08:24:29 AM
by eyezlee
Last post Apr 28, 2005, 09:06:32 PM
by shooter
Last post Jun 04, 2005, 11:10:15 PM
by crawlerdan
Last post Mar 12, 2008, 06:18:39 AM
by snowrun
