will a detroit locker for a V6 toy rear work in a 4cyl 8" housing with 4cyl gear
Started by stone4x4, January 26, 2005, 07:27:18 PM
stone4x4
need help if there is a diff what is it (the size,bearings......... ?)
GOD MADE DIRT AND DIRT DON'T HURT
toybuilt
1983 Toyota Turned Chevy
no direct experience with v6's  but ive heard the bearing in the 6 are bigger
sandboxtoy
the v6 carrier (detroit locker) uses larger side bearings then the 4 cyl.  the pinion bearing is also larger. 4cyl gears will work in the v6 third but the v6 gear is stronger due to more tooth contact. the only interchangeable parts are 4 cyl gears to v6 third member and pinion yokes (driveline flange).
eyezlee
A v6 carrier will fit in a 4cyl housing with the correct bearings.  the dimensions of the v6 bearings are (aprox):  50mm id x 83mm od.  the dimensions of the 4cyl bearing is 45mm x 79-80 ish.  there is a bearing that will allow a 55mm id and 79-80ish od (I think marlin even sells it as a kit).  I have found a bearing that will allow a 4 cyl carrier in a v6 housing (produced by sks bearings) but haven't found anyone able to actually supply it so I cannot verify if it will work.
Matt
'87 '60
'96 '80
