Author Topic: 91 22re reving funny  (Read 1935 times)
toeyota
  • Member since Jun '07
« on: Nov 12, 2007, 05:04:48 PM »
When ever my 91 model is idleing, and i turn on the AC, it starts to idle up and down constantly like the compresser is kicking on and off. I know it should do it every now any then but its...up and down up and down up and down. Again it only does it at idle. Any opinions on what this could be? Ive never had a toyota with AC so im lost :gap:
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
Re: 91 22re reving funny
« Reply #1 on: Nov 12, 2007, 10:39:26 PM »
Could be air bubble in the cooling system or the tps is mal-adjusted.
toeyota [OP]
« Reply #2 on: Nov 13, 2007, 04:32:29 AM »
hmmm, no idea about fuel injected 22r's... It idles around 1100 rpm also if that tells you anything. Im going to go over it good this evening checking the timing and everything.
jonathan82toy
  • Turtle Points: 5
  • Male Posts: 502
  • Member since Mar '07
  • 1St Gens Rule!
« Reply #3 on: Nov 13, 2007, 10:15:08 AM »
Adjust your timing and idle. My 90 did that before I tuned it.
What Is The Truth Behind The Magic Turtle Breeding Program?
S.S. More Powerful Than Superman, Batman, Spiderman And The Incredible Hulk Put Together.
  • Male Posts: 9,757
« Reply #4 on: Nov 13, 2007, 01:19:51 PM »
Yup, forgot to mention to start with your idle.  Doesn't have to be too high before it'll starte surging.
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
« Reply #5 on: Nov 13, 2007, 01:25:00 PM »
In order:
Adjust Timing 5*BTDC
Adjust Idle to 850RPM
Adjust TPS to FSM spec.
toeyota [OP]
« Reply #6 on: Nov 13, 2007, 06:27:50 PM »
ok thanks alot. i got another problem now. The motor is making a fairly load tapping noise. Sounds really like a valve out of adjustment, but i checked all the valves and they were adjusted almost perfect. I went ahead and got them just right but the noise is still there. Im hoping its the injectors... I tried the seafoam treatment, but no luck yet. I guess my questions is how can i figure out if its injectors making the noise? As far as i can tell it is on the top end of the engine. I even pulled plugs one at a time and the noise persisted throughout that process. Thanks alot for the help.
Forgot to add, my timing chain is due to be replaced by feeling of it while i had the valve cover off, but im pretty sure thats not making the noise im hearing. Its almost more of a click than a tap.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #7 on: Nov 13, 2007, 06:47:14 PM »
replace the chain chad,  btw  dump yopur pm box  its FULL  and wont let me pm you
93tonkatoy
  • Turtle Points: 5
  • Male Posts: 463
  • Member since Jul '07
  • drive it till it breaks! then break out the tools.
« Reply #8 on: Nov 13, 2007, 06:57:43 PM »
were the timing chain guides intact? The chain slapping the cover sounds about like what you're describing.
SAVE TELLICO post 491
toeyota [OP]
« Reply #9 on: Nov 14, 2007, 04:11:09 AM »
yea there intact but very very flimsy.
*ROKTOY*
  • Male Posts: 1,066
  • Member since Nov '06
« Reply #10 on: Nov 14, 2007, 06:08:52 AM »
OK, you are right the idle is supposed go up and down with the ac on. Check and make sure that the compressor is not cycling on and off as the idle goes up & down. If it is you could be low on refrigerant, if not there maybe a problem with you ac idle up solenoid. As far as the timing chain goes, I would say its time for a new one.
toeyota [OP]
« Reply #11 on: Nov 14, 2007, 04:09:35 PM »
yea def time for a chain, but the noise isnt comming from there. Its in the valve train. The valves ar at 8 and 12, but i guess it could just need a valve job or somthing. Im about to head over to a guy that only works on toyotas and knows what hes doing, ill see what he thinks about the racket.
I went to every other shop around here and they say that noise is normal, alittle bit loud, but normal. Another thing that its got 10-30 in in it right now, tomorrow ill put some 20-50 castrol and see if that dampens it any.thanks for the help.
Last post Feb 09, 2003, 10:09:50 PM
by mr4x42u
Last post Dec 14, 2003, 10:49:22 AM
by 79coyotefrg
Last post May 16, 2004, 03:49:21 PM
by 79coyotefrg
Last post Sep 20, 2007, 08:17:09 PM
by emsvitil
Last post Jan 07, 2008, 03:54:21 PM
by Mega Baby Huey
