My friend used to work in an auto body shop and said to use a razor blade to carefully cut down the clear runs and then wet sand it with 1500 grit.
I just painted my truck and I have areas of lots of orange peal and areas of lots of runs. My friend used to work in an auto body shop and said to use a razor blade to carefully cut down the clear runs and then wet sand it with 1500 grit.
You aren't suppose to cut the run with the razor blade. you are suppose to scrape it carefully. scrape it till it is flush with the paint, then wet sand it.
Started by wslytoy Parts For Sale
Started by kneedownnate Project Research and Build-Ups
Started by Makohon « 1 2 » Project Research and Build-Ups
Started by cruzila Trail Reports, Events, and Gatherings
Started by TacoRunner General 4WD Discussion
