atoyoT 4-Runner SAS
Started by Loosekannon, October 21, 2007, 10:16:54 PM
toywthbdydmge
#210
dizzydevil
Quote from: toywthbdydmge on November 26, 2007, 04:04:42 PM
OTHER PAYMENT METHODS  YOUR  :moon: or
He's just lucky PEPS didn't do it or else it would still be IFS  :rofl2: :beer:
:ha_ha: :haha: :laugh: <<<<< brawlers     peps>>>>>>> :down:
Loosekannon
Quote from: atoyot on November 26, 2007, 02:01:59 PM
hey chase and jason thanks for all the hard work and time you guys put into my 4unner. i went to allpro today and had peps ramp my 4unner. the drag link and the tie rod are not an issue :biggthumpup:. they dont touch when flexed flat. and the only trimming that has to be done is the rear fenders. the front tires clear with no problem.
i ll stop by next month so i could cut my fenders. and if you got time maybe help me with my bump stops and extentions :beerchug:
No prob  :thumbs: It was fun to bluild. So how does it handle, you liking it? Is my half ass alignment job doing alright? Just wondering how it did, does it pull one way or the other? I'l cut those fenders up for ya  :disturbed:
atoyot
Quote from: Loosekannon on November 26, 2007, 10:08:30 PM
yeahp it doesnt pull at all but after the night i drove it home the steering wheel was slightly to the left but no big deal. i havent got it aligned yet. ill let you know when i come up there again
dizzydevil
dosen't pull? was there ever a thought that it would?   :rivers: i am hurt
:greengrin:
atoyot
Quote from: dizzydevil on November 27, 2007, 07:37:31 PM
:greengrin:
remember i dont know as much as you guys know but i thought it would drive pretty decent with chases alignment :biggthumpup: which it did but i still gotta do that aliggnment soon. and i gotta nother question about tire pressure. does the rear have more pressure than the front or the opposite for daily driving?
should be a little more in rear for you.. that 4runner top is heavy.
atoyot
Quote from: ImaPostHoToy85 on November 28, 2007, 08:53:59 AM
is there a certain psi it should be at for a dd
most tire shops recommend 35psi for most light truck, suvs and 4WD trucks. 45-50psi for 8lugs, and 30-32psi for passenger cars.
so i will recommend 30psi to you in front and 33-35psi in back
iNfErNaL
I run 30 psi. on my Daily Driver on 35s.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
right now on my DD im running 23psi for winter right now.
to grip more.
but im light and it floats fine :]
Tool Pimp
I got my DD sitting at 90psi but it also weights 20K lbs  :gap:
Quote from: Tool Pimp on November 28, 2007, 04:37:14 PM
:yikes:
are you running steel moon rover tires? :rofl:
Loosekannon
On my Swapers I ran 15psi in the front and 10 in the rear on the street. It rode alot better like that. You don't need a full 35psi, your truck is not that heavy. But then again your tires a radials. We will f :lipsrsealed: k with it next time you come up  :thumbs:
dizzydevil
atoyot
Quote from: Loosekannon on November 28, 2007, 09:44:03 PM
right now i got front and rear at 30psi. im gonna try 25 front and 20 rear
iNfErNaL
Yo Max,I'd probably keep it at 30 psi.Your truck may not be that heavy but it'll still feel a little top heavy around turns.5 and 10 pounds less may not seem like a big difference but it is,specially when you're used to the way your rig handles with no lift and 31s and then add a lift and 37s,your center of gravity is different now.I would consider running it at 30 psi for now,but that's just me.
30psi
i down with that number too.
toywthbdydmge
dizzydevil
No front drive shaft yet...no gears yet!
toywthbdydmge
Quote from: dizzydevil on December 10, 2007, 07:30:38 PM
wtf kind of workers are you guys  :headscratch: :rofl2: :beerchug:
dizzydevil
can only install what he buys.....he didn't have the cash for dual cases or 4.7's
Loosekannon
Still need to find out WTF tranmission he has to see if the gear drive case will fit.  :headscratch: He is saving up for 4.7's
jedrattle
Quote from: Loosekannon on December 10, 2007, 08:26:39 PM
What year? What motor? Auto or stick?
`87 runner....it was stock....now sas'd, 37's, duals, geared/ locked, 10in bob, half doors, rock lights. etc., etc.,.........coming soon a 3.4 swap!!!
http://board.marlincrawler.com/index.php?topic=39332.0
www.rockbrawlers.com
Loosekannon
93 or 94, 22re, 5 speed and has drive flangs on the front axle. The T-case is a chain drive. The only thing different is the flanges.  :dunno:
Was wondering if a gear drive case will work on that tranny.  :headscratch:
iNfErNaL
Quote from: Loosekannon on December 11, 2007, 09:43:40 AM
  :yesnod: as far as I know.
Loosekannon
Quote from: Infernal on December 11, 2007, 10:00:15 AM
That what I figured, don't think Toyota would make a tranny for a 22re that used a V6 t-case. Just thought it was wierd to see a chain drive case in there
atoyot
Quote from: Loosekannon on December 11, 2007, 06:35:16 PM
what would i need to get if i just want to run the 4.7s? i also was wondering how would i modify my drive shaft to get a steeper angle or would i have to get one custom made?.
right now all my $ went away cuz i moved down to san diego and bought all kinds of furniture. so it would be a while till i get that $ i need for the gears. but i was looking to get the dual cases carlos had if he still had them for 700 but no cash
