Author Topic: Leaking Axles when steering arms removed... normal?  (Read 3130 times)
mmessier2
  • Turtle Points: -2
  • Member since Mar '06
« on: Oct 04, 2007, 09:23:46 AM »
I am slowly working on installing my high steer on my 85 4runner.  When I removed the steering arms on the tops of each knuckle it seems as if the weight shifted and most of the oil from the axle began to leak out from end of the axle (around the knuckle).  Probably at least a quarts worth.
Is this normal, or did I somehow blow my inner axle seals and they need to be replaced?
IronClad
  • Turtle Points: 635
  • Male Posts: 2,284
  • Member since Feb '05
  • Annihilation Fabrication
Yep id say that would be normal. when you removed the steering arm it put weight on the axleshaft thus putting weight on the inner axle seal.. which is not known for holding worth anything.  so you probably need to replace them
Do you need a Hammer?
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Are your tires on the ground or is the front jacked up?
DTB
  • Shoutbox Moderator
  • Turtle Points: 2
  • Male Posts: 7,110
  • Member since Nov '05
UHHHHHHHHH  :talkingn:
Quote
MiniSimp
  • Male Posts: 5,120
Seen it done before... :gap:
DTB
  • Turtle Points: 2
  • Male Posts: 7,110
was this a clue?
Quote
mmessier2 [OP]
  • Turtle Points: -2
It is on a jack.
So...  should I replace the seals or not?
MiniSimp
  • Male Posts: 5,120
I would replace them with Marlin's new HD Front Axle Seals.
http://board.marlincrawler.com/index.php?topic=32224.0
mmessier2 [OP]
  • Turtle Points: -2
I just ordered a full rebuild kit off Marlin...  I have a geared 5.29 3rd that I need to swap in, so I will have to pull the axles anyways, might as well rebuild it while I'm there.
subliminaltrips
  • Turtle Points: -1
  • Member since Sep '06
x infinity... keep in mind the rebuild kit doesnt come with the hd seals you have to order them seperate.
Last post Mar 23, 2004, 09:59:09 PM
by Thumper
Last post Jun 13, 2004, 11:19:09 PM
by 84runner
Last post Feb 17, 2006, 11:40:52 PM
by E YOTA
Last post Mar 31, 2006, 11:26:26 AM
by TacoRunner
Last post Aug 23, 2014, 11:34:36 AM
by helipilot77
