TEAL '85 extra cab build...
Started by SolidAxle, September 28, 2007, 09:32:09 PM
Quote from: tom w. on October 18, 2007, 10:18:42 AM
Actually, now that I think about it, mine is an auto convert...
from auto or to auto?
and whats your plans on lift Tom?
SolidAxle
Allright guys i've got a question. At the moment i don't want to sped the time completely fixing and bedlining my floor (not that its that rotten) and i was thinking of grinding down the rusty a bit and spraying on black paint so when the time comes for me to really fix it it won't be as hard to get off as say por 15. suggestions?
halfxspaid
Get a flap disk or wire wheel and take some of that rust down as much as you can.
I would suggest then spraying it clean with some carb-cleaner and spraying some rustoleum on it.
Then throw a summitracing $100 new carpet down and call it good.
85 longbed - Caged, locked, dual'd and armored
halfxspaid
Oh and congrats on the w56 swap!  I did it and it was the best mod so far!
How did you drill the big hole for the master?  I muscled some hole saw in there from the engine side.  :gap:
tom w.
Quote from: 3WM Yoda on October 18, 2007, 12:03:25 PM
From auto to 5-speed.
Quote from: 4runner666 on October 18, 2007, 01:12:55 PM
I don't know. I've never had to deal with rust like that.
Quote from: halfxspaid on October 18, 2007, 01:18:42 PM
if i get an auto... ill be swapping to W56 5Speed as well. ill use these lil threads to help.
im liking your build up bud.
keep us informed.
tell us what your plans are my friend.
SolidAxle
#36
I took my whole dash out 4runnerrick style, and then slammed a holesaw through from the inside out. the holes i drilled for the studs were bigger that the spacers and i was crapping my pants thinking I drilled the holes way off lol.
Quote from: halfxspaid on October 18, 2007, 01:16:25 PM
Don't want to put a carpet back in, if my floor is going to rot I atleast want to see it  :cheese:. jokes aside that is what made it start to rot. there was a small drill hole (i think for the plastic that goes on the inner front wheelwell where water (nasty bad salty water) was geeting in and then is soaked into the carpet and sat there. That and coolant, i got a new heater core to go in before i put my dash back together too.
I got some Duplicolor bedliner in a rattle can at work today. i tested it on a scrap piece of metal, pics will be up soon.
I know this question has been asked in a bunch of different threads but what wires do i need to put together to "trick" the computer to think its in neutral and what ones to make reverse lights work?
SolidAxle
Duplicolor Bed Liner test piece pictures...
Can
Wet
Dry (it really has the same texture as when its wet, picture just sucks)
I am going to test out its durability :greengrin: tomorrow once its completely dry.
NorCalToy
im also only 15. its nice to get a young start on truck building.
btw truck is looking good. good job on the tranny swap.
:flamer: IFS
SolidAxle
Quote from: viperred89 on October 18, 2007, 08:46:58 PM
Im also only 15. its nice to get a young start on truck building.
Thanks, I bought my first parts truck when i was 14 or 15. The motor out of it is whats going in my truck now. Good luck on your build.  :thumbs:
tom w.
Quote from: 4runner666 on October 18, 2007, 07:34:20 PM
Dude, let me go see real quick. I vaguely remember doin' that when we first swapped a manual into this truck, but I don't remember where it was.
tom w.
Sorry dude... I have absolutely no idea how I got it to work.
there are a few other threads on here that state which wires..... wheres everyone at on this?
halfxspaid
It is a plug located under the intake.  Its a round plug that has three wires, two larger and one small.  You unplugged this connector when you dropped the auto.
You need to connect the two thick wires together.  I think they are both black.
SolidAxle
Quote from: halfxspaid on October 19, 2007, 10:39:39 AM
sounds good, I'll have a look.
that the only wires?
halfxspaid
3WM - Im not sure what your asking?  What I described is the only wire you need to hook up to bypass the neutral safety switch.
There are wires there involved in reverse lights and 4wd indicator lights that I am not familiar with.  If anyone knows, post up!
Quote from: halfxspaid on October 20, 2007, 01:30:31 PM
you ended up covering what i asked. =]
86bobbedtoy
Quote from: 86bobbedtoy on October 20, 2007, 08:20:58 PM
great build so far
i agree.
oh not to jack the thread...but i got my Half doors....for my next truck, my buddy gave 'em to me.
ill post pics later.
look in my build thread.
SolidAxle
Thanks for the compliments guys.
I went to change my heater core on yesterday and after an hour of trying to get it out (i thought i could sneak it out without taking the whole black box out) i finally get it out and its perfectly fine :mad: . So then i take a look and find that one of the tubes that runs through the fire wall has a nice split in it (so thats why the guy i bought it off of had the heater switch disconnected). I made an emergency run up to my aunts house where my parts trucks live, and had the whole thing disassembled and out in about 5 minutes, although the dash was already out.
Today I put my new heater core in, just in case. I don't want to take that apart again anytime soon. and got all heater related stuff back in.
Tomorrow i plan on
1. wire wheeling all the rust spots in the cab and spraying rust converter on  them.
2.Bedlining the portion behind my pedal assembly so i can put it back in.
3. cutting holes out my floor for the w56 and maybe putting it in after i clean up the crossmember.
This is why my truck doesn't go in the garage. My dads car (can anybody guess what it is)
thats a roadrunner my friend.
=] 70?
SolidAxle
Incorrect.
hint, there is a swirly dustcloud in the stripe (If you are a big mopar guy you can peg the year of it by that)
SolidAxle
UPDATES.
Didn't do as much as i planned today. I had to go out for my Grandmother'sbirthday.
But i did manage to accomplish this...
And here is a picture of my dads daily driver next to my truck.  :thumbs: He's had it since i was 5. This is also what i currently drive when i can.
Quote from: 4runner666 on October 21, 2007, 06:57:23 PM
UPDATES.
a barefoot pedal! NOICE! thats a classic  :biggthumpup:
Duffil
[joedirt]I had to get a footprint gas pedal installed, so I stole this heep.[/joedirt]
Nice job so far.  Keep it up.
86bobbedtoy
Just gas and gears,
Do you really need anything else?
not really. a few rocks or trees will stop ya
SolidAxle
Thanks guys,
It was certainly an adventure finding that pedal. the other 2 pedals are beinginstalled tomorrow for the last time. I didn't get feet ones of them because it would be a little excessive but i did order 2 new pedal pads from Toyota $5 a piece (remember I'm in Canada so prices on everything are different. usually more  :mad: ). I don't know if i work tomorrow but i hope to get the pedals in regardless. Tranny tunnel cut and tranny in if I'm lucky.
