Author Topic: Swamp cooler tech!!!  (Read 3792 times)
werty
  • Turtle Points: 5
  • Member since Sep '03
  • i need a martin crawler
« on: Aug 04, 2007, 12:37:02 PM »
First things first water. Water is a main staple out here in the desert.
The water is sent from the local mercury/cyanide filled under ground water supply via piping to my house.
From the its teed off to the cooler on the roof.
The water enters the cooler via a toilet valve. Limiting the water from running over the edge of the coolers sides.
Water that dose run over is evaporated by the intense heat before it hits the ground.
This little pump sends an amazing 5 GPM to the top of the cooler to be dispersed by the the 8 spider legs of pissing doom.
It is pissing on the roof!
The water is dispersed thru little slots in in the top of each side. The water is then soaked in the the fibrous matting in each side.
Once water is flowing and the mat's are wet its time to move some air thru the house. On high this blower moves  4500 CFM
 Thats a lot of air.
The air is cooled by the water in the mat's as its pulled thru from the blower.
On the inside is a 18''x18'' box that the air is pushed thru. Depending on what windows are cracked in the house, is where the air will fow to and cool
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
Re: Swamp cooler tech!!!
« Reply #1 on: Aug 04, 2007, 12:41:26 PM »
so  it's a real install system  and not some redneck thing    very very informative
thx you for explaning it
but how much difrence in temps do U see  :dunno:
Willy Mammoth
  • Male Posts: 4,252
  • Member since Nov '04
« Reply #2 on: Aug 04, 2007, 12:43:51 PM »
The water is being used as a refrigerant. It is OK to release this refrigerant as it is only water and as far as we know it does not effect the ozone layer.
It is the evaporation of the water that cools the air just like when your sweat dries off your skin it cools you down.
Now that works well except for when the air is saturated and can not hold anymore water, then it just blows wet air.
baconator
  • Turtle Points: 2
  • Male Posts: 383
  • Member since Jun '07
  • when you gotta go, you gotta go
« Reply #3 on: Aug 04, 2007, 12:45:11 PM »
looks good.  have you experienced the sauna effect when you had no windows cracked?
check out the first project from Born Crazy Customs
Quote from: MrsWillyMammoth
OK so we got the thick bacon... but RK can't find the salami... and Deans wife has the cheese...
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #4 on: Aug 04, 2007, 12:46:02 PM »
what about mold build up   from the wet mats and stuff ?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Aug 04, 2007, 12:50:30 PM »
to make it  cooler  you need to keep the water going up there as cool as possible
runthe water line  thru the roof  not over it
also  if  you make yourself a  "water cooler"  you can reduce the temps even more
if  you took the pump  and  ran a line  that  goes from the  pump to the top of the swamp cooler,  run a 1/4 inch copper line  down into the house  with a  coil of tube ran into your refrigerator,  then  running it from there back  to the top of the swamp cooler
takes alot of tube  but  will really  reduce  the temp of the water
werty [OP]
  • Turtle Points: 5
« Reply #6 on: Aug 04, 2007, 12:51:52 PM »
yep when its hazy out side and humid it dosen't work
You can see the Kat houses in the distance. Along with the heat haze over the mountians.
unclejpl4x4  the temp dropped  15 degrees when I tured it on. a cool 72 now
werty [OP]
  • Turtle Points: 5
« Reply #7 on: Aug 04, 2007, 12:53:39 PM »
no lol that would suck we just turn it off when its to humid
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #8 on: Aug 04, 2007, 12:53:43 PM »
i still would like a dieagram  maybe someing  in MS paint
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #9 on: Aug 04, 2007, 12:55:05 PM »
but  do you guys still use reg AC units out there  ?      dose everone have a swamp cooler
baconator
  • Turtle Points: 2
  • Male Posts: 383
« Reply #10 on: Aug 04, 2007, 12:59:08 PM »
i made the mistake of running the swamp cooler in our shop with the doors closed while i went to lunch and when i got back it was about 110* and 100% humidity.  sauna effect isnt fun
werty [OP]
  • Turtle Points: 5
« Reply #11 on: Aug 04, 2007, 01:00:02 PM »
nope out here its the best thing for the heat lots of people have ac but this is more cost effective.
*** YELLER ***
  • BIGMIKE SAID I WAS A CLOWN SO .... GUESS THATS THAT
  • Turtle Points: 314
  • Male Posts: 4,686
  • Member since Oct '05
  • USMC NO BETTER FRIEND NO WORSE ENEMY
    • Buy me a soda
« Reply #12 on: Aug 04, 2007, 01:00:29 PM »
Now if it gets crazy hot and it feels like the cooler just aint workin' go to the grocery store and buy some blocks of ice and drop them in da coola and see how much that drops the air temp. (if you have an ice maker save some in plastic baggies and use it in da coola)
No this is not a joke it works and I do it every year when my fat ass gets too hot its like AC without da bill
 :usa: :beerwhack:
except BACON
Tallchevy
  • Turtle Points: 236
  • Male Posts: 3,562
  • Member since Dec '06
« Reply #13 on: Aug 04, 2007, 01:05:53 PM »
 :usa: :beerwhack:
X2
87 4Runner redo
werty [OP]
  • Turtle Points: 5
« Reply #14 on: Aug 04, 2007, 01:09:04 PM »
unclejpl4x4
  • Male Posts: 3,522
  • Broke & rusted
    • myspace
« Reply #15 on: Aug 04, 2007, 01:15:28 PM »
:rofl:
werty [OP]
  • Turtle Points: 5
« Reply #16 on: Aug 04, 2007, 01:24:29 PM »
They are cheep .. like 5 bucks or less a piece... like heater filters on steroids.
They were new 2 years ago. So all I do is wash them off before the first time they get used in the spring.
mold ??? There no stinking mold, just calcium build up. thats easy to get rid of when its dry with a broom.
Stocker
  • Turtle Points: 962
  • Male Posts: 173
  • Since 1977
« Reply #17 on: Aug 04, 2007, 01:30:19 PM »
Great descriptions, and love the diagram!    :haha:  Haven't heard of using ice cubes, I'll have to try it.
That looks just like the one that's been cooling my house since 1990.  Starting to rust out though, it'll need replaced before too long.  Lots cheaper than A/C!   :gap:
My goal in life is to be as a good a person as my dog already thinks I am.
If you don't learn something every day, you're not paying attention.
werty [OP]
  • Turtle Points: 5
« Reply #18 on: Aug 04, 2007, 01:32:23 PM »
you pulling 5lbs of stuff out of the bottom in the spring too?
Stocker
  • Male Posts: 173
  • Since 1977
« Reply #19 on: Aug 04, 2007, 02:46:21 PM »
Are you talking about minerals etc from the water, or all the junk that breaks away from the pads?
Our water isn't bad, very little stuff from that.  I do get some pad material, but I always clean it out, then drain it and dry everything before covering the cooler for the winter.  In the spring I usually just oil the bearing blocks and turn the water on, and it's good to go.
Lady Di
  • Goddess of Mud
  • Female Posts: 299
« Reply #20 on: Aug 04, 2007, 02:54:16 PM »
OMG!! He really did a thread!!  :rofl:
Your diagram is excellent!! :thumbs:  but that would not work in our FL. humidity!
A swamp cooler doesn't cool swamps!
:talkingn:
I kill me!  :rofl2:
« Last Edit: Aug 04, 2007, 03:18:27 PM by MrsWillyMammoth »
Life is like a bowl of beer flavored chocolate covered dog turds.. it makes no sense. :pokinit:
Where is the Mammoth?
How the Mammoth came to be
Number Two :pokinit:
werty [OP]
  • Turtle Points: 5
« Reply #21 on: Aug 04, 2007, 03:41:19 PM »
junk that builds up in my'n is rust, calcium, dirt, cause its windy in winter time, shingle rocks :???: .
Stocker
  • Male Posts: 173
  • Since 1977
« Reply #22 on: Aug 04, 2007, 03:49:12 PM »
Sorry to hear it -- mine stays a lot cleaner inside.  Also, I got a heavy canvas cover for it (~$30, iirc) for the off season...
werty [OP]
  • Turtle Points: 5
« Reply #23 on: Aug 04, 2007, 04:46:41 PM »
I need to get one of those.
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #24 on: Aug 05, 2007, 12:17:44 AM »
You haven't??  I could have sworn I told either you or mom about putting ice in mine at the last house.  Cubes melt off too fast, blocks work better.  You should have plenty of space in that big freezer since you don't have it stocked with bear meat anymore :gap:
Swamp coolers work pretty well around here.  I got home from work about 11 tonight and the house was WAAAY hotter inside than it was outside.  Ran the pump for 5-10 minutes before turning it on and it's blowing cold within a few minutes.  Worst part of it is it makes me congested and snotty, which is now made worse by my stupid summer flu :shake:
Stocker
  • Male Posts: 173
  • Since 1977
« Reply #25 on: Aug 05, 2007, 07:02:07 AM »
Nate, you probably told me about the ice -- but I'm getting forgetful in my old age!!   :disturbed:
And yeah, I meant 'block', but typed 'cubes' instead  :shakehead:
Sorry to hear you caught the crud, hope you get rid of it soon!   :sick:
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #26 on: Aug 05, 2007, 02:27:53 PM »
I don't envy you guys!  We get a hand full of days that it's above 85* and the rest is very comfortable.  And the winter is just wet and cool.  And we get a hand full of days where it's freezing!  The rest of the year we're around 50-60*
Stocker
  • Male Posts: 173
  • Since 1977
« Reply #27 on: Aug 05, 2007, 03:21:43 PM »
cheesemaker, you truly do live in a beautiful part of the country! :thumbs:
Cheesemaker
  • Male Posts: 4,525
« Reply #28 on: Aug 06, 2007, 08:24:19 AM »
Thanks!  Sometimes I forget until I go somewhere else.  Went to Fresno/Disneyland last summer and all I saw was brown!  I love how green everything is here!
werty [OP]
  • Turtle Points: 5
« Reply #29 on: Aug 07, 2007, 06:57:09 PM »
I miss brookings OR cause of the all the green. Hell the hottest day was like 93. Most the time its mid 60s. 50s in the winter and a few weeks in the 70s during summer.
Last post Jan 13, 2003, 10:38:05 AM
by cruzila
Last post Jan 06, 2005, 10:16:53 AM
by Red_Chili
Last post Dec 30, 2005, 06:58:31 PM
by BUDDERS
Last post Apr 21, 2006, 08:48:47 AM
by abnormaltoy
Last post Sep 07, 2006, 02:01:33 PM
by Shoyrtt
