propane setup
Started by Thumper, August 02, 2007, 11:05:40 PM
Thumper
ive seen lots of people running the propane setup on there yotas on here but havent heard where too get this at. can someone post up at site that sells the propane setup.
thanks
adam
If you didn't make it, and it ain't broke, you didn't try hard enough.
gtoyonrocks
http://www.gotpropane.com/ here you go, Carey is the own, he is the man when it comes to propane. If you have any questions give him a call or email him.  :gap:
1985 toy, Hybrid 20r/22r on propane, 30splines, custom built leaf packs, welded front and rear diffs, dual ultimate crawler, full hydro, full exo, flat bed, 37' mtrs
Thumper
thanks never knew it was so expensive but well worth it.
thanks again
adam
Shamb
I've started doing research on propane kits as well, gotpropane.com is the way to go for sure.
I'll be getting this kit................................ eventually..
KYOTA also has a nice write up on installation of Carey's kit!
You've also gotta calculate in cost for tank (s) and adapters for maybe a BBQ and or converting to those small bottles in an emergency.
I'd assume your looking at a good $1000
AaronB
Carey had been talking about a dual fuel setup I wonder if that is still in the works, It would be nice for us Cali. peeps
Quote from: skipnrocks on November 08, 2011, 05:36:37 PM
unclejpl4x4
we have duel fuel on alot of areial lifts   gas or propane     i myself would like 2 see a duel fuel toy kit    can't be that hard with the right parts.
the only thing with propane is after a while you get oil build up in the propane manifold   and has 2 be cleaned.
gtoyonrocks
He does have a dual fuel set up. I'm running his proprane kit on my yota, it's awesome, it's so simple. I would much rather run propane than have computer controled fuel injection. I want to say the kit cost around $800.00, if you ask me that's a bargain. It's really easy to install, and is mantinence free. I would recommend propain for anyone, even those guys that are running fuel injection. There are a lot of pros to propain. On average it's 107-110 octane, it doesn't go bad, it's very enviormentally friendly, it's about a dollar cheaper a gallon. Do I really need to say more. It runs at any angle. You can build a hybrid motor, the hybrid on propane is bitchen. If anyone has any questions give Carey a call.
KYOTA
toy4x4ota
just did this swap on my truck and love it, the only thing i am having trouble with is my throttle seems to be sticking but i dont think it has anything to do with the kit.  i just need to try and lube up the linkage and see if that works.  also instead of running the solenoid off of a keyed on source i ran it to a swith so if it is off then the truck wont start, flip the switch and it fires right up. also good for theft
Liqour in the front   Poker in the rear
LIFTED TRUCKS ARE GAY
85 toy, 223:1, welded/welded, 38's, running on PANE
gtoyonrocks
That's a good idea, I hope you like you propane kit, I love mine
toy4x4ota
just curious if it is a good idea to run the forklift tanks vertical. i have heard and read that they are to be used in the horizontal posistion, but i have also seen a few rigs doing it the other way, like the tin benders jambo f-toy. it is not going to cause a problem doing that way then that is what i am going to do so i can run two tanks and still have plenty of room.
sam24462
#12
Wrecked
unclejpl4x4
Quote from: toy4x4ota on November 20, 2007, 06:51:08 AM
just curious if it is a good idea to run the forklift tanks vertical. i have heard and read that they are to be used in the horizontal position, but i have also seen a few rigs doing it the other way, like the tin benders jambo f-toy. it is not going to cause a problem doing that way then that is what i am going to do so i can run two tanks and still have plenty of room.
we have equipment at work  that has them both mounted up and sideways  same moter same type of equipment
toy4x4ota
so are you saying that it will work? same motor, same type of equipment, do they run the same?
unclejpl4x4
It should not matter.   The reason  some are upright and some laying down  is just for fitability.
Say  if you have a choped bed or no bed  i would put it upright.   If i had tons of bed space i would put down.
Just not upsidedown.
toy4x4ota
well im tight on bedspace so that is why i ask, but i have a feeling that the tanks are supposed to be ran horizontally.  maybe i should just call cary
snowshoebrue
you can run the tanks either way.  if you run them laying down you need to make sure the hole in the handle points down and the safety valve points up.  the tube has about a 30 degree kick on the end of it to pick up the liquid on the bottom when it is layed flat.  if you don't watch that you will run out at half tank.
and on the usage it took me 8.5-9 gallons to run the con from loon to tahoe
toy4x4ota
so i shouldnt run into any problems with running them vertically?  is the pickup for the tank on the bottom?
toy4x4ota
anybody with any more insight on which way the tanks can be ran????
snowshoebrue
ya you can run them upright.  the pickup tube goes all the way to the bottom it just has a kick at the end so that it can pick it up when its on its side
toy4x4ota
awesome thanks for the picture and the help, this is gonna save me bedspace
skipnrocks
Quote from: Thumper on August 03, 2007, 05:25:25 PM
thanks again
adam
Is the cost of propane cheap enough to counter the cost of the kit?  and is it hard to find a source for refill, or do you just have to make sure you have enough for the trip?
WILLYNILLY
snowshoebrue
propane here is like 1.25 cheaper than gas.  i usually have enough propane with me for the whole trip.  if i have to get it i can get it at the gas station, but it is like 40 cents cheaper to get it from the propane supplier
skipnrocks
huh, not bad, if I wasnt worried about availability since my rig is a dd then I might commit.... hows your economy compare?
WILLYNILLY
46&2
I didnt see it mentioned on here per se or on the gotpropane site but what kind of mileage do you guys get? any specific numbers? just curious i have never heard any exact "MPG" stats for propane.
BLACKDOG
Quote from: skipnrocks on November 27, 2007, 09:13:23 PM
I don't think you have to worry too much about availability.  Out here, a lot of gas stations have propane fill ups, as do uhaul rental places.  Most places that refill your BBQ tanks will refill your forklift tanks.  I know some places won't, due to liability for some reason, but most will.  :thumbs:
              -Ronald Reagan
skipnrocks
Quote from: BLACKDOG on November 27, 2007, 09:18:21 PM
Not the case back home, the older stations used to do propane, and so did uhaul but not anymore, you can get it from the gas company, but I dont know of any other places that do...  I wish I was lucky like you guys and had them all over...
WILLYNILLY
Angler
Has anyone running propane had any experience with super cold temperatures affecting the propane? I am interested in running pane on my 84 but I am stationed in Fairbanks, AK and it is -40F as I type :thumbdown:. I would like to know if anyone has any experience with this?
skipnrocks
I have a buddy running dual, propane/regular petrol here.  In the winter time he says they have to use the regular gas to get started and warm and then flip the switch...
WILLYNILLY
