DBL-EXX build up
Started by werty, July 28, 2007, 06:14:32 PM
why the JIC fittings?
PAGE 2 IS MADE POSSIBLE BY IMAHOTO87
unclejpl4x4
Quote from: ImaHoToy87 on January 20, 2008, 05:33:37 AM
I perfer o-ring face seal my self
werty
Quote from: unclejpl4x4 on January 20, 2008, 05:49:00 AM
Its a mixture of 16x1.5mm singsaw fitting and jic and a 14x1.5mm singsaw for the return outlet.
the fuel lines run up the D.S. on the blazer and I wanted the fuel lines on the P.S.
werty
WOOOT the 700r4 is Done!!!!!!!!!!! transpak and outputshaft in 7 hours. My uncle Steven helped out with the tear down and reasembly. Worse part was putting the 2,4, clutch packs back into the bottom cage. ARG wow 20 minutes of puing my hair out. pics tomarrow.
werty
Its so close i can smell the gas burning. tranny tunnel is almost done.
werty
werty
Looks like a coke bottle. :haha:
werty
blinging stereo holder and switch pannel.
Doof
looks good. i like that tranny tunnel :thumbs:
topar
 :thumbsup: Looks Damn good!  You should paint that tunnel like a coke bottle  :yesnod:
Doof
werty
Quote from: topar on January 27, 2008, 08:08:27 PM
maybe pepsi or carona
WOW! that looks damn good man.
Doof
thats a :pokinit: ton of welding on that tunnel... i bet that got old after a while
skipnrocks
Cool cover, x2 on the bottle!  Are you going to put a removable skin over the rest of it?
WILLYNILLY
Quote from: skipnrocks on January 28, 2008, 02:08:35 PM
x3! and yeah a removable skin would rock
werty
Quote from: sillywilly on January 28, 2008, 10:25:00 AM
It took 4 hours to do with .030 flux core. welding the 16g to the toyota sheet metal was the worst part, weld burn thru fix, weld burn thru fix , weld burn thru fix, ya it sucked!
The top and back will look like the switch pannels. the rest of the cab will get a coating of "rubber under coating".
skipnrocks
Sounds cool!!  I know how it is welding older steel to newer steel! Burnouts suck!
WILLYNILLY
Goose
Looks sweet!
Thats one hell of a tunnel..
Is that Darth Vader On your dash?  :headscratch:
Baller Status: Coming Soon To A Toyota Near You!...   :afro:
My Life Is A Very Complicated Drinking Game... -Me
90 ext. cab v6, SAS'd, 37's
94 4runner -work in progress
www.slagfactory.com
My Buildups:
'90 ext. cab
http://board.marlincrawler.com/index.php?topic=38260.new#new
'94 4Runner
http://board.marlincrawler.com/index.php?topic=53882.new#new
werty
Quote from: Goose on January 28, 2008, 06:03:08 PM
Looks sweet!
Yes he is my copilot even dose the heavy breathing sound. Got one of the 4 out of the one box burger king had. The girl at the register got a 5 buck tip for letting me have it. here is a pic of it new.
werty
Got the oil and tranny cooler all in one kit from summit. The cool ness is the remote oil filter I can mount anyplace. This is not a bad kit for 96 bucks!
werty
frontranges  tcase mount.
werty
4.3L IS IN THE TRUCK
slow progress, but looking good
werty
Sorry its taking so long! I'm in the middle of moving. So I'm cleaning up everything too. So there wont be any progress for a month or two.
70 Cam Guy
Quote from: werty on January 27, 2008, 06:54:22 PM
cool rack mount handles  :cool:
werty
Quote from: 70 Cam Guy on February 04, 2008, 10:15:41 PM
Thanks I get them for free from work. Wait till I do the hood. The handles are spring loaded and go flat too.
Redbeard1
Quote from: werty on January 28, 2008, 05:23:44 PM
A little trick I use for welding sheet metal is to find you a block of brass and hold it to the back side of the weld area gives you somthing to build a puddle on. Then you just tap it with a hammer after the weld cools and it comes right off no more burn out and fix...
If you dont stand behind our Troops... you can stand infront of them...
Project Pete==> http://board.marlincrawler.com/index.php?topic=43370.0
85 Toy: Built 22re, locked F, spooled R, 5.29's, R151F, MCO7 duals, Sky x-member 37 MT/R's on jack stands
__________________________________________
||____________||____________||___TOYOTA ___||
||____________||____________||_____________||
RIP Bobby Long
skipnrocks
WILLYNILLY
