DBL-EXX build up
Started by werty, July 28, 2007, 06:14:32 PM
85toyin
Quote from: werty on April 19, 2008, 03:22:55 PM
I also finished the fuel lines. I hope i can fire it up tomorrow  :driving:
Looks good, I also did my fuel lines, pump and filter today. Turns out that the lines I got say "not for fuel injection systems", but oh well....Not pulling them unless I have to. You run your radiator in the bed right? Do you have any pics of this set up? I like that red line!!
85 Toy, 4.3/700R4...work in progress
werty
Quote from: 85toyin on April 19, 2008, 06:09:32 PM
I haven't gotten that far yet on the radiator, soon. The red line was 30 bucks for 30 feet. Thats Napa's cost! I think it runs $3.50 a foot. 140psi 3/8s fuel line. Bling!! Your 4.3l harness will be done Tuesday. I welded up a oil filter bracket and got it installed.
werty
werty
I'm hoping to have almost a gallon and a half of oil in the system.  :rockingout:
What oil filter holds a quart and a half and is 18mm x 1.5 thread?
unclejpl4x4
werty
I can say that today is a good day the truck RUNS
:clap: The 4.3l started right up. Deafeningly loud, no engine codes, or leaks yet. I ran it for a minute or two to get oil flowing. Radiator mounts and tubes to the back are next the tcase cross member and testing it out on the trail. :driving:
Colt
 :willynilly: it runs! excellent! Isn`t it a good feeling?  :eyebrow:
werty
So much stress is gone because it does run and my wiring is perfect. Except the oil light being on So I think it is time for a mechanical sweeper. The oil pressure sender dosen't have enough resistance to turn the light off. Well I will see if I can run a after market gage.
85toyin
Quote from: werty on April 22, 2008, 08:04:52 AM
Glad to hear it man!....I can't wait till mine is running..That will definately ease my mind a tad. Also glad ot hear that your wiring is perfect since you have my harness!! lol  Congrats on the fire up!
werty
Quote from: 85toyin on April 22, 2008, 05:36:15 PM
Your harness is almost done!
Almost done doing the radiator mounts. I took the for sale sign out of the yard and used it for the fan shroud then attached the ford taurus fan to it I think it came out nice.
werty
Started the mounts on the truck for the radiator.
werty
 :sick: i think i got strep throat i only got to work an hour last night before i couldn't breath anymore. This is all I got done.
85toyin
Nice start, I'm ready to see some more progress so I can get an idea how to do mine!! :thumbs:
werty
radiator is in.
werty
two
werty
reason for it being at an angle?
you should get an updated pic for your avatar :gap:
werty
Quote from: that HO kid on April 28, 2008, 12:39:44 AM
the top hose is a pain to take off strait up and down. So i angled it a bit. It looks cooler this way.
agreed, more mud bogger idea!
werty
update In 08 :flamer: getting the custom cross member welded up. Made a twin stick. The usual.
http://www.reno4x4.com/forum/showthread.php?t=16679
werty
werty
got a big aluminum top for the back seat and a air horn for a buck.
werty
more of the crossmember.
werty
a
werty
e
werty
i
werty
o
i want to see this thing under its own power! get crackin :gap: :whip:
85toyin
Hey Matt, Think the fan and rad thickness is ok to run up front?
I can't find cheap hose...That sounds awesome!!
I just can't see spending over 100 for hose to run in the rear...I would like to, but that is more than I want to spend.
We have the same rad, tranny cooler and soon to be fan...Think it will fit.
I still need to go pull a fan from the bone yard.
