My vehicle is a 2000 4x4 with the 3rz engine W59 transmission with the stock T-case.
The other day I had my truck in 4wheel drive to get some rocks for my neighbors wall that he is building and when I stepped on the trucks brakes the truck stopped but it felt like it slide forward did not think much of it out in the field. When I reached the hard payment road it did it again even with the weight of the rocks in the bed, took it out of 4wheel drive and tried it again it stopped on a dime no movement what so ever. After the rocks were unloaded in my neighbors yard, we were playing with the trucks 4 wheel drive system in his driveway when ever the truck comes to a stop forward or reverse no matter what type of terrain the truck is in or what speed the truck is at or even what range of 4wheel drive it is in when the truck comes to a stop it feel like it is sliding in the direction the truck was moving in. This only happens when in 4wheel drive Please help.
What was checked
Checked the rear drive shaft and the transfer cases rear flange it had very little movement,
Pulled the rear tires and checked the rear brakes and shoes no leaks and are in good condition
checked the fluid level of the rear diff , t-case and transmission, no leaks fluid is at normal level and still has the color of purple.
Checked the rear axle shafts both move in tire direction and has no side to side movement.
No modifications were done, the entire drive line is stock.
My neighbor looked under the truck while I went forward and reverse he seen no abnormal movement.
