Question about transfer case in my setup
Started by Chevota22, July 19, 2014, 02:11:27 PM
Chevota22
Ok, I have an 86 Toyota with a SAS, 4.3 vortec and 4l60e tranny.... My question is the transfer case was originally mated to a manual tranny....
So I used gear oil in the t case.... Now it is mated to an auto tranny.... In the chiltons I have for the truck it says that t cases mounted to a/t use ATF and the ones mounted to manual trannys use gear oil.... So, the question is.... Is there a difference between the t cases mounted to different trannys or were they just trying to use the same fluid for each in case a seal went bad and fluids combined? What should I put in mine? Sorry for a possibly dumb question but I need to know. Thanks...
emsvitil
I believe they're   different.
Use the gear oil.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Chevota22
Ok that was the plan until I looked it up and saw that there was ATF in some.
Thanks for the response.
RCKSQRL
ATF is only in toyota auto transfer cases. Gear drive cases have gear oil
Sent from magic wish granting phone
'85 EFI Runner
4.3 with 700R4- for sale
5.29 detroit F/R
Front 3 Link with air shocks
rear 4 Link
Custom Fuel cell
8274
Crawler #719, rear with 4.70 # 677,
Twin stick
Skys manufacturing T-case crossmember
6 point cage modified with harness bar, dash bar and PRP seats mounted to cage
2 feet chopped off the back
It seems it is never done........
in works for new body and exo, motor and trans swap...
