Author Topic: Sloppy Rear T-Case Output  (Read 1579 times)
TrikeKid
  • Turtle Points: 782
  • Male Posts: 165
  • Member since Jan '06
« on: Jul 15, 2007, 10:02:44 AM »
I noticed some driveshaft shake at certain speeds the other day, so I crawled under and did the "everything is still bolted on" check, and the output on my case has some slop in it. Can I fix that with just by tightening the nut up, or am I going to need to replace the bearing?
85 Xtra-Cab- stuff and things.
Duffil
  • *lurker*
  • Turtle Points: 138
  • Male Posts: 4,844
  • Member since Nov '04
    • PhotoBucket
Re: Sloppy Rear T-Case Output
« Reply #1 on: Jul 15, 2007, 12:28:06 PM »
yeah, sometimes the nut gets loose.  pull the driveshaft and tighten it up.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Jul 15, 2007, 12:47:24 PM »
pull the driveshaft off  see if the nut is loose,  if  it is  take the flange off  and see if the output shaft is  actually  loose,  if so   you need , most likely  a  tcase rebuild
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #3 on: Jul 15, 2007, 01:05:27 PM »
There will always be a little play, but you don't want to see a lot.
TrikeKid [OP]
  • Male Posts: 165
« Reply #4 on: Jul 15, 2007, 02:52:44 PM »
Thanks guys, would the same go for the rear diff I just need to keep it on the road till the end of the month when I can have the local 'Yota guy do up some gears for me.
Duffil
  • *lurker*
  • Male Posts: 4,844
    • PhotoBucket
« Reply #5 on: Jul 15, 2007, 03:33:19 PM »
drive it easy
TrikeKid [OP]
  • Male Posts: 165
« Reply #6 on: Jul 15, 2007, 04:18:21 PM »
I haven't had the chance to drive it hard yet, I just wanted to get rid of the driveshaft vibes. Front shaft is about I___________________I that far away from runnable or I'd have it bolted in and have my 4wd.
Last post Jan 09, 2004, 08:01:12 PM
by cruzila
Last post Feb 15, 2004, 09:47:23 AM
by krawlr
Last post Jul 30, 2004, 03:31:06 PM
by 84runner
Last post Aug 28, 2005, 10:27:34 PM
by mad squirrel
Last post Mar 30, 2008, 08:18:48 AM
by blackdiamond
