hey did you pull the plugs after cleaning the carb or befor or at the same time maybe you already fixed your problem
man nobody?? ok things are desparatebrb
when I had to "engineer" a vacuum leak so i would lean out enough to smog, I pulled the thermo valve line, just after the tee to the MC valve. Leaned out pretty good, it's a direct manifold port. I would look there, your charcoal canister hoses as well, esp. where it goes onto the carb.
i am really getting to the point of buying like 25 feet of hose and just giving the whole system a "face lift"
thank you, thats a step in the right direction, i'll take a look at those lines. i am really getting to the point of buying like 25 feet of hose and just giving the whole system a "face lift"
Why not just cap off/remove all lines that don't directly effect running Mine is an 80 and all I have hooked up is vaccuum advance and brake booster, though I am running a weber. I did have everything hooked up at one time but decided to simlify things a little.
Started by Plekto Engine
Started by spaded1 Toyota Pickup/4Runner Tech 1979-95
Started by 85yotabox Engine
Started by BG88 « 1 2 » New Member Check-In!
Started by opus Engine
