hold on..... popped the hood and saw inside the fuel filter and saw it was sucking more fuel?you have a carb - did someone add an aftermarket fuel filter to your truck? the carbed trucks have a white plastic fuel filter mounted above the gas tank.. or a big goofy black thing under the hood... how did you see inside of it?
Have you checked to see if your floats are stucks, i know when i had a carbed S-10, the floats stucks and it did the exact same thing..military_stang
you arent running a weber 32/36 are you??
Started by alwayzbroken Engine
Started by blackdiamond General 4WD Discussion
Started by toy4crawlin Toyota Pickup/4Runner Tech 1979-95
Started by robrub00 Toyota Pickup/4Runner Tech 1979-95
Started by pyrosnow911 Engine
