NEED HELP IMMEDIATELY!!!! (now with video of the problem)
Started by MiniSimp, May 25, 2007, 07:13:12 PM
MiniSimp
Quote from: Duffil on May 25, 2007, 09:34:43 PM
do you have anyway of checking your timing
No
Quote from: Duffil on May 25, 2007, 09:34:43 PMand did you check to see the dissy hadn't rotated/bolt was tight?
Looked good :dunno:
Quote from: Duffil on May 25, 2007, 09:34:43 PMreal low idle,
idle is 900rpm
I'm no mechanic, so I only do what I know which is limited.
Axles/trannys/transfer cases and gears I can tear apart and rebuild no problem.....Engines I SUCK at!!!!
Duffil
looks like it's fix-minis-hunk-of-:pokinit:-so-it-lasts-thru-the-trail when we get there. :rofl:
MiniSimp
Quote from: Duffil on May 25, 2007, 09:47:02 PM
:talkingn: That's the official mame of the run!
highridin4x4
Did you get it fixed on friday? was it you tps?
Scott
MiniSimp
Quote from: highridin4x4 on May 27, 2007, 10:22:18 PM
Scott
No idea what it was, Duffil adjusted the TPS a the trailhead and that did nothing, so I decided I was going to run the trail even if I had to idle through the whole thing, and it all of a sudden started working again. Later on the trail I turned off the truck, then turned it back on and same thing, kinda sounds like it's running on 2 cyl. Then it started running perfect again. :screwy:
highridin4x4
Dont you hate the gremlins that come and go when they please. Do you have a spare tps to try out?
MiniSimp
Quote from: highridin4x4 on May 27, 2007, 11:01:40 PM
Nope. :shake:
Willy Mammoth
Tallchevy
Check your spark plug wires, I had the same problem & went to change the plugs & found that the wire that crimps to the clip that snaps onto the spark plug was gone & the boot was holding the wire in place. Also I had a coil crack & the spark would jump to ground. Wait until it's dark, have someone crank the engine & see if the spark is jumping. Did any onf the wires get burned by the exhaust? I had that problem too  :crossed: :twocents:
87 4Runner redo
Duffil
highridin4x4
I actuly have a spare tps. I dont know if it works I got it from a wercking yard but you are welcome to try it. I also work in livermore so I could drop it off after work some day.
Scott
