Project Toyotal Chaos
Started by ben_teq, May 20, 2007, 11:42:51 AM
MRHilux87
What kinda boost numbers and turbo combo are you running?  Cant wait to check it out at MCR13.
1987 4Runner.   3RZ.  SAS Duals 5.29 Elocker Rear Detroit front 35s... Hydro assist
2007 Cummins 6.7 DRW g56.  deleted EFI live.
2013 Ninja 1000
SOLD:
2006 Mitsibishi EVO 9.  347WHP runs 12.2s - Wifes daily driver.  Ducati 916 - track bike.
HogCanyonHopper
this truck is going to be at MCR13?!?  saweeeet   :beerchug:
ben_teq
Quote from: MRHilux87 on June 29, 2014, 02:13:57 AM
They are factory JDM spec twin turbos that will be running at 11 ish psi. I want to keep everything stock and reliable.
Quote from: theslayer85 on June 26, 2014, 09:26:01 AM
Nice build.  You are making the 2jz swap look way too easy and now I want to do it.  Is that the same truck?  The front cowl looks tan and your other truck was blue and white.
Same truck yes, the fenders and hood are bright white primer, hopefully getting sprayed the factory tan soon.
Quote from: HogCanyonHopper on June 29, 2014, 01:24:31 PM
I kinda doubt it but maybe, it would depend on my work contract. I was hoping MCR13 would have been in September. MCR14 for sure, I would like the drive the truck down the coast with the wifey and make a good holiday out of it next year.
Thanx for the comments dudes. The truck is coming along nicely. I have it 99% wired up now and the "to do" list is getting smaller. Sorry I haven't had time to keep this thread updated but i'll try and get a video up this week. She runs super smooth and makes the 7m sound like an old tractor motor
I only had about 6 wires to hookup for the engine wiring but dam it took a long time to finish it all up. I tossed new braided sleeve on everything else in the process. Its busy but at least no stray wires. Also note the igniter mounts under the dash and doesn't just dangle there  :D
This is where everything ties into the factory cab harness, still uses factory gauge cluster.
New relayed fuseblock for cd player and ecu power
Nation
Dingman.
zippo
If you see it, its for sale.
ben_teq
Small update ...got the new heat exchanger installed. The truck is pretty much ready to go, I just need my 1 wire 240amp alternator to show up.
Poser shot...
zidaro
'87runner.
'10 Crewmax
'05 CRF450x
http://www.4wheelunderground.com/
TONIK- Mammoth Lakes
Nation
Yeah man. this thing is epic wish I had something else to say...
twistedtoy92
The chaos never ends... Brilliant work man!
Nation
ben_teq
Sorry no video yet. The truck worked great for a first time out. I had some issues with the fuel pump control so I ended up wiring it direct off ign for now. We thought the fuel was vaporizing at first (that's why the hoods off). Other then that no issues besides needing a better power steering pump and some new valve stem seals. Check out some pics
You can see here im trying to crawl up with the starter...I didn't quite have enough fuel in the tank to keep the motor running on this angle...noob mistake :(
All downhill from here...
twistedtoy92
Nation
ben_teq
Quote from: NATION on October 18, 2014, 06:28:55 AM
Video video video!
https://www.youtube.com/watch?v=DN50XB_DOoE&feature=player_detailpage
I tossed this vid together after Fj-Rankenstein and I went for a Sunday drive...Its not hardcore by any means.
Hopefully I can get another video together sometime soon.
Wainiha
2000 3.4L xtra-cab Tacoma.
Icon C/Os
Marlin 1200lb. clutch
Marlin short shifter
FLOODED...GONE
2005 4.0L xtra-cab Tacoma
FLOODED...GONE
2012 4.0L xtra-cab 4x4 Tacoma
Automatic...Don't shoot...
King resi C/O
and Total Chaos UCAs
Wainiha
Icon C/Os
FLOODED...GONE
FLOODED...GONE
King resi C/O
theslayer85
A turbo diesel and a twin turbo supra motor.  I like it.  You guys give Canada a good name.
floorrunner
87 4runner, 97 3RZ, dual ultimates, 5.29's air over elocker & arb, true longs R.I.P., York belt driven onboard air and a/c.
ben_teq
#200
Hey Marlin dudes check out our local club if your bored. A few of us Canucks have some cool builds coming down the pipe so stay tuned on https://www.facebook.com/Toontoys306
Dingman.
zippo
I am thinking of a 2jzte swap. How much room to do have between the front and the core support?  If I used a water to air intercooler could you fit a radiator?
:)bestgen4runner
I am 1/5th of Perfect Fit
