Author Topic: Adapter Plate Help Marlin  (Read 2919 times)
Thumper
  • Turtle Points: 63
  • Member since Dec '03
« on: Apr 01, 2004, 12:39:38 PM »
Ok i need to know if anyone makes a plate too go from a granny gear 4 speed chevy tranny too a toyota transfer case. :help:
im thinking about putting a V8 :thumbs: in my truck and have a 4 speed with a 7.03 granny gear and im wanting too put duel toyota cases behind it for a super low ratio. :driving:
just need too know if you make or anyone else makes an adapter too go from 4 speed too toyota.
thanks
adam :yupyup:
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
Re: Adapter Plate Help Marlin
« Reply #1 on: Apr 01, 2004, 12:49:55 PM »
Your talking about a SM420 and yes we make an adapter that will enable you to run a gear driven Toyota transfercase (RF1A) directly behind the 4 speed GM tranny.
Click here for more details on our ToyBox adapter, Part Number: MC20
Here is an example of P/N# MC20 on the SM420, Courtesy of River City Rock Crawlers:
Regards,
« Last Edit: Apr 01, 2004, 12:51:34 PM by BigMike »
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #2 on: Apr 02, 2004, 08:18:35 PM »
Our MC 20 adapter is a two peice design, and is only 1.5" long.
First you bolt the front plate to the back of the SM420, and then bolt the second plate to the front of the pick up t/case.
Finally, both plates are then bolted togeather with the supplied 6 outer bolts.
This kit also includes a 10 spline female input gear that was made in Japan by the orginal gear cutter.
We also supply the front housing of the pick up t/case that has been modified to accept a larger input bearing that is also supplied.
Marlin
Thumper [OP]
  • Turtle Points: 63
« Reply #3 on: Apr 02, 2004, 09:14:17 PM »
Hey thanks guys for the info on the swap how much is the mc-20 with the front housing that you were talking about marlin.
if i order the kit ur talking about i can just bolt my toyota transfer case right too the back of my sm420 tranny and just run 1 toyota transfer case behind it for now,then buy my duelcase adapter later, and do i have to run the landcruiser transfercase or can i run my truck transfercase like u were saying i think.
thanks for the help
adam
Marlin
  • Male Posts: 856
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #4 on: Apr 04, 2004, 11:09:53 PM »
We have adapters to bolt the single mini-truck gear driven t-case to the SM420, or you can add a dual case or even bolt up a one or two peice [split] Land Cruiser case.
Please give us a call and ask for Cruiser Dave, he can explain how it works.
Marlin
Last post Jul 19, 2004, 04:30:48 PM
by BirdDog
Last post Feb 27, 2005, 04:56:45 PM
by JackKnife
Last post Jan 11, 2006, 06:37:39 AM
by BigMike
Last post Apr 18, 2008, 09:23:40 PM
by WHITE_TRASH
Last post May 07, 2009, 09:13:28 PM
by THE ROCK
