soo i finally got my 22rte back new pics added> build started
Started by robrub00, April 14, 2007, 02:04:48 PM
unclejpl4x4
looking good  wish i could get my block 2 the machine shop :down:
hey thats my shoe! lol.....
i'll be workign on that engine in a few hours. lol
robrub00
more pics to come soon,
  progress made recently (not that anyone is followingthis thread  but me haha)
exhaust manifold is taken to the ceramic coating place.
newer style valve cover is getting powdercoated blue
sent shifters to get doglegged so i can shift the dang thing
  got injectors back from ace fuel systems and had them flow tested.
installed new orings and seals and installed injectors and fuel rail.
painted intake manifole and mounted. started on vacume lines and coolant lines
clocked ct26 and got the holes drilled to mount up to new manifold!
things to do still
plug in wiring haRNESS and finish vacume and water lines------done
attach fly wheel and centerforce dual friction clutch------done
drop engine in with lc mounts.  bolt to tranny-----done
plumb turbo and intercooler  ---done except no intercooler plubed just want it to run
get 3 inch exhaust  work
( at least the down pipe, so i can drive it ( loudly) to a exhaust shop
add oil and filter and add oil directly in turbo
add coolant and radiator after flushing of corse
clean fuel tank and swap walbro pump in
add belts
add starter-------done
adjust tps
adjust timming
get gas in tank
connect fuel lines to engine at fiter.
swap brake booster with dual diaphram and bigger master cylinder
put brake lines back on
bleed brakes and clutch
put in new battery
put suspension back together.
put drive lines on----done
turn key
get friends
find one that can weld
drive to friends house to begin welding  crossover high steer install and chevy spring hangers
install high pinon and  low pinion elockers and 4.88 gears
save more money
drive to marlin and set up appoint ment to get my dual cases installed with 4.7 gears that are sitting on my shelf! along with fror crossmember
get some kind of skidplate for use with mco7r10
maybe flatbelly
relocate fuel tank( might be sooner than i think on this mod)
find some rocksliders
kick butt!
ok ok anything that i am missing  chime in please,  or anything that seems rediculous  chime in!!!
bunch of stuff for sale!!!!------> http://board.marlincrawler.com/index.php?topic=31225.0
Tallchevy
Quote from: robrub00 on June 21, 2007, 03:20:52 AM
Looking good  :thumbs: but what happened to the bikini top  :dunno:
87 4Runner redo
Quote from: Tallchevy350 on June 21, 2007, 09:44:22 AM
oh yeah, that mod is in their somewhere... but thats one of the luxury things, lol
Tallchevy
Quote from: jimbo74 on June 21, 2007, 09:54:44 AM
:headscratch: It is way cheaper than anything he has listed that he would have to buy!
87 4Runner redo
robrub00
havent got to the bikini top.  cuz no battery means no rolling the rear window down and no removing the top to wok on it lol.  went to vegas for a week then went back to work for a buch.  got the engine install;ed today with my lc engineering motor mounts. ill try to get pics up.  still have to do some stuff before it runs!( like work out the exhaust problem im having.  also i decided im not going to wory about the body wiring till i try to start it.  if it runs ill be happy. iff not ill try and fix the problem then!!! haha
robrub00
also i bought a full floating rear axle from a toyota rv.  im trying to get asome more info on it but im lost.  i heard i could use the front hubs and calipers but i need a bracket.  any write ups on this??
i want to eventually go with this axle modified for a elocker  and some 30 splines for the front.   that should make it so i dont break anything very easily!!!
bling bling...... haha, wheres my thanks? ! j/k its all good, youll be working on my truck next month when i get back from down undah'
you call that a knife?! that aint a knife! this is a knife!!!!!   :flamer:
as far as the full float, it isnt a steer axle, its a rear axkle... even with lockout hubs, it istill inst a steer axle
robrub00
Quote from: jimbo74 on July 30, 2007, 01:40:01 AM
i know it's not a steer axle.  i want to run it cuz full floaters ytend to lose wheel bearings instead of axle shafts and then a set of 30's for my front will lessen the chance of carnage in the front.  did i type steer somewhere.
have fun down under!  bring me back a koala in a kangaroo's pouch holding a boom -a- rng.  ok maybe just a boom-a-rang lol jk
ah, i htought you meant running longs in front wit hte ff... i was like um..... trippin... lol... haha its late..... sent you a pm with specs
robrub00
unclejpl4x4
YotaChris
Very nice. Can't wait till I get the engine I'm building done.   :down:
I LOVE MY YOTAS!!
Ewong
There was a writeup on SOME forum (Pirate?) that was all about the FF from the RVs
I think most people use FROF's kit instead
yeah yeah - still IFS...
robrub00
got the manifold and the turbo bolted on and the starter and swaped the valve cover
robrub00
robrub00
robrub00
new color... haha you like...   all i need to do is get the belts on and radiator. fill them with oil and fluid.  bleed brakes and clutch and fill power steering.  cut a hole in the floor board( need a sawz all blade, all mine are broke.
than put the leaf springs and shocks back on, and then i can tow it to the exhaust shop.  then i can turn the key!!!!
werty
Did you add oil to the turbo lines before you hooked them up? fast way to ruin a turbo is not having oil in the lines on the first start up. It takes a few seconds for the oil to get to the turbo from the pump and by that time the turbo is spooling allready.
robrub00
yeah i added oil first!!!!!  thanks good looking out though!
Tallchevy
Just pull the fuse for the computer so the injectors won't fire & crank the engine until you have good oil pressure. Then re-install the fuse & start the engine. You can also remove the coil wire & do the same thing  :twocents:
87 4Runner redo
robrub00
i think  ill do that .  that would be easier!!!!!!! haha  thanks man.
baconator
supra turbo??  are you building a crawler or a drag truck? :rofl2:  looks sweet either way
check out the first project from Born Crazy Customs
Quote from: MrsWillyMammoth
OK so we got the thick bacon... but RK can't find the salami... and Deans wife has the cheese...
robrub00
Quote from: baconator on August 21, 2007, 04:53:27 AM
we will see, haha.  i want to get to tahoe up the grade quicker and i want it to crawl!  we will see.
robrub00
hahah  i haven't been on here in a while.  so an update.  i was away on the fires down south and i was getting hassled by my local Community Service Officer ( writes parking tickets etc)  they said my disabled vehicle in my drive way had to be shown to run or a 300 ticket would be given.  well i was gone 18 days in malibu and san diego so my dad had my toyota towed to a shop.  well 2 months later the shop calls  and got all the kinks worked out and it was running!!  code 11 was on the cheack engine light,   but  that was ok cuz   it was running like crud! before and a bunch of stuff had to be done to get it running.  so he got it running called me to come look at  it drive it etc.  he started it up for me and 5 sec later he reved it.  after he reved it there was  a ticking sound!  that was not right!   he says he thinks it is a main bearing!!!!!!!!  so now  i have a $3000+  engine with a main bearing  that is busted ( not confirmed)  well i went to the machine shop and the guy who built my engine wants me to bring him the oil filter sooo im bringing it to him tommarrow!!! he wants to see if there is any metal in it??  it is so frustrating.  ( it does sound good with the 3 inch exhaust!!!)  and it was nice to see it move under its own power for once!   so thing i have done and had done lately  i had the 3 inch exhaust put on with custom  turbo elbow made!.  i lifted it so the 33's wouldnt rub.  ( sits way higher in the front,  need to get the alcans put on front and rear!!!( i bought them already!)  I decided on a top mount intercooler from an audi  that i got for 25 dollers!!! NEED TO pipe IT AFTER I GET IT RUNNING.   i still have the msd ignition to install,  i have  a 5.29 elocker that i picked  up on here i need to modify the axle. still need to do the dual cases that are sitting in my garage,  the sky front widening kit,  the drive line break the crossover and histeer conversion and install the interior cage and get my hipinion elocker  geared for 5.29 and installed, longfieleds...instaled with cryod hub gears and i picked up some 4crawler rock sliders too.  I am Crazy( im starting to feel like it will never be done!!
ps i also picked up a 87 4runner running for a good price from a fire capt.!!!  ive been driving that til i get the blue 85 running.  it has 5.29's  and 4 inch lift!! its ifs  but what the heck!.  i had to change the upper and lower a arm and idler arm and other parts so it wont pull the the right.  got it alighned.  i swaped the fender and hood( still not  perfect but better)  looking to sell it as soon as i get the 85 22rte running
unclejpl4x4
hold on your trucks in your drive way   YOURDRIVEWAY  and u have 2 prove it runs........  i tho U lived in the US not nazi germany  :dunno:
anyway that sucks 2 hear about the moter  thats why i do stuff like that my self http://board.marlincrawler.com/index.php?topic=39214.0
robrub00
nice motor Unc.  that is sweet.  i Dont have time or the tools for that  right now.  when i started the project it was right before medic school in 2004/05  it'sbeen a learning process,  and dont get me started on the thing being in my drive way.  2nd time it has been tagged!!!!!
unclejpl4x4
put up a sign on  your truck  tresspasser will be shot
