Author Topic: 86 toyota short bed turbo problems  (Read 4009 times)
OregonCrawler
  • Male Posts: 29
  • Member since Apr '07
    • nationalprojector.com
« on: Apr 11, 2007, 02:03:20 PM »
hey im having a problem with my 86 toyota pickup.Its got the turbo :smack: and as soon as it ingages (@ around 2500-3000 rpms) the green light comes one and it dies :tantrum:.well it spudders and if you keep your foot in it it dies.What could be causing this?I got it used and its done this the hole time.Any info or ideas would be awsome! thanks  :help: :help: :help: :help:
rude86
  • Turtle Points: -14
  • Male Posts: 257
  • Member since Sep '05
  • if it aint broke you arnt trying hard enough
Re: 86 toyota short bed turbo problems
« Reply #1 on: Apr 11, 2007, 03:41:12 PM »
thats the same thing my turbo did the night it died forever. have it checked out befor its to late.
member of team marlin crawler
OregonCrawler [OP]
  • Male Posts: 29
« Reply #2 on: Apr 11, 2007, 04:21:38 PM »
 :nerv: ok well that sounds good  :shocking: ill have it checked out.Any one else have this prolem...? man now im realy freaked out!
rude86
  • Male Posts: 257
« Reply #3 on: Apr 11, 2007, 04:46:49 PM »
mine started out as a head gasket. it was leaking so much water into the cylinders and mixing in with the fuel thus forth causing a miss fire in one cylinder. ran like crap. i think when it died i killed the turbo because it wasn't boosting like it usually would.
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #4 on: Apr 11, 2007, 06:11:56 PM »
Another reason I'm getting rid of the turbo setup and going to 22re!  The way I look at it is this, a rebuilt motor with a cam, a good flowing head, header, and a 2.25" exhaust, will give you the same or more horsepower as a good running 22rte with factory turbo.  It will cost more to have a 22rte rebuilt than a 22re.  And the added cost of the turbo (ct20) being rebuilt, or trying to find and modify a good working ct26 (from a supra/celica?)  Most turbo rebuilds will cost ya some serious dough, just for a little component!  You can get aftermarket turbo's to replace the stock one, but how much do ya want to spend?  This is probably the reason the last owners decided to sell the truck!  Do your research and decide what your gonna do!  I've been told that the turbo stuff will swap over for the 22re, just need a ecm that is for a 22re.  And maybe different injectors!  I'm going to be finding out real soon!  As soon as I get my butt in gear and order the motor!
I'd check all the airflow connections, check your timing, fuel pressure, and anything else you can look at.  Oh! just thought of this, the fuel filter!  It might be plugged up!  It's easy to replace, but can be trying if you got large hands!  It requires a 12mm socket and a 17 mm wrench to replace!
I don't mean to scare you away from a turbo setup.  Mine is not running and I want to start fresh, and get the best bang for my buck!  Low budget build ya know!
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #5 on: Apr 11, 2007, 06:49:27 PM »
I loved my Turbo, never had the issue you're talking about, but the oem is crap and you may want to look into something like a Supra turbo. Check and make sure someone didn't disconnect the vaccum line to the wastegate. Some people do that thinking it will produce more power, it doesn't but it sure will screw things up.
OregonCrawler [OP]
  • Male Posts: 29
« Reply #6 on: Apr 11, 2007, 07:26:19 PM »
hey there is a disconected fuel line with a screw in it to plug it.I duno where to plug it back in but hey mabe thats my problem!! any one know where to plug it back in>????????????? let me know thanks!
rude86
  • Male Posts: 257
« Reply #7 on: Apr 12, 2007, 08:29:19 AM »
weres it at??? tank or motor??? pics would help.
Cheesemaker
  • Male Posts: 4,525
« Reply #8 on: Apr 12, 2007, 01:42:51 PM »
It's got to be a return line!  Hey, I remember the pics of your truck in your other post, and I remember a few vacuum lines missing off the tpi!  Maybe that could be some places to look at also!
OregonCrawler [OP]
  • Male Posts: 29
« Reply #9 on: Apr 12, 2007, 02:32:51 PM »
yeah what are those?There plugged with little ruber caps and zip tires.I have no idea where they go?
  • Administrator
  • Turtle Points: 2158
  • Male Posts: 18,292
  • Member since Apr '02
  • 511:1 Club
« Reply #10 on: Apr 12, 2007, 04:03:50 PM »
I am not sure which line controls the waste gate, but if it is not connected, then you might be overboosting. Does the check engine light come on for about 10 seconds and then turn back off?
Lousy pre-OBDII systems :sheerterror:
rexandfx
  • Turtle Points: -7
  • Male Posts: 50
  • Member since Oct '05
  • hill-billy ramp travel
« Reply #11 on: Apr 12, 2007, 05:56:20 PM »
As your looking at the pic, the one on the left, goes to the fuel purge canister, and the Right one, goes to a little assembly of steel vacuum lines, that are usually mounted to the side of your valve cover. looks like yours is gone.
I am not sure how old this pic is, but you have nothing connected to your TPS. I see an open plug there.
86 4runner 22rte- stock...for now
81 jeep cherokee widetrack fullsize- also stock...for now
OregonCrawler [OP]
  • Male Posts: 29
« Reply #12 on: Apr 12, 2007, 06:41:58 PM »
this was a recent pic..I just pluged the tps and it made some difference..I dont realy under stand where the little hoses should go(tho ones with the red arows) got any pics?
Cheesemaker
  • Male Posts: 4,525
« Reply #13 on: Apr 12, 2007, 07:28:12 PM »
He's also missing all the egr stuff, and where does that taped hard line go, that is mounted right in front of your cold start injector?
Cheesemaker
  • Male Posts: 4,525
« Reply #14 on: Apr 12, 2007, 07:29:25 PM »
Why is your TPS unplugged?
OregonCrawler [OP]
  • Male Posts: 29
« Reply #15 on: Apr 12, 2007, 07:37:59 PM »
well I got the truck from an auto wrecking place (it was repoed) so idk you would have to ask the origional owner but theres wires and hoses all over the place un plugged so idk lol but its plugged in now!
SACD_Runner
  • Turtle Points: 2
  • Male Posts: 217
  • Member since Mar '07
« Reply #16 on: Apr 13, 2007, 12:06:10 AM »
ok I guess i'll use my ricer knowledge for some good use now. :) The wastegate can be ran off any vacume source. I would do a couple of things.
Is the wastegate hooked up to a vacume source? are there any kinks in the line?
Do you have any leaks/cracks in the DP or intake?
hows your idle? rough/smooth?
Are you gaining any boost at all? If so is the compressor making a chatter noise..? <- this is a long shot
Truely any question on your setup can be answered here www.Homemadeturbo.com , i use to be a member back when i had my 4G63t powered EG hatch. They'll answere anything you can't find by running a search, Almost every problem involving a turbo has been discussed or resolved. Good luck, oh and Please no jokes. and too anyone thats had real boost under their toes, Its addictive!
For those who wanted to see. :)
Starting from scratch again...
Last post Sep 23, 2005, 05:47:52 PM
by wa4x4
Last post Sep 10, 2006, 09:45:23 PM
by Rocksurfer
Last post Mar 05, 2009, 06:38:28 AM
by Cheesemaker
Last post Feb 20, 2017, 08:05:58 PM
by Blk Scout 800
Last post Jul 08, 2014, 08:10:31 PM
by ntsqd
