Author Topic: IFS Steering Box  (Read 5133 times)
pmweiler offroader
  • Member since Mar '04
IFS Steering Box
« on: Mar 18, 2004, 07:46:04 PM »
 :bowdown:Are there instructions (with pictures!) for mounting the IFS steering box on my '83 Toy. I just purchased Marlin's awesome high steer kit. I want to make sure I do it right the first time  :crossed:
  • Turtle Points: 679
  • Member since Feb '03
  • Don't blame me, I didn't vote for this crap.
Re:IFS Steering Box
« Reply #1 on: Mar 19, 2004, 03:04:49 AM »
wrong section  Heres your answer, it is really easy to put the box on your frame.  When I did mine (84) I just used an origional steering box hole to line up the rear most hole on the new box.  Really easy to figure it all out then.
WT
« Last Edit: Mar 19, 2004, 03:05:53 AM by WHITE_TRASH »
Brandon
  • Hawk
  • Turtle Points: 193
  • I believe in Life before Death
    • www.RiverCityRockCrawlers.com
Re: IFS Steering Box
« Reply #2 on: Apr 01, 2004, 04:37:07 PM »
since he has the kit with the upper tab you have one point decided allready. Personally I cut my own plates for BOTH sides of the frame (bad experience in the past), I put the two bottom holes parallel in the middle of the frame and slide them till the pitman barely clears and that is where it goes. I take a hole saw and cut out the frame to fit in pipe to sandwich between the frame and plates and drill the box out to fit the 1/2" bolts and that is it! Not sure on the kit though..
Brandon Miller
RCRC, Sacramento, CA
SloCrawler
  • Turtle Points: -116
  • Male Posts: 1,333
  • Member since Mar '08
    • http://board.marlincrawler.com/index.php?topic=60800.msg856812#msg856812
« Reply #3 on: Jun 04, 2010, 04:14:57 PM »
I'm doing it right know on my 81. Because I'm doing RUF I had to plasma out sum of my body to fit it foward. It's a pain if you have traction bar up front. Got to cut and grind off the original Chinese hack job.
fade
  • Turtle Points: -9
  • Male Posts: 1,018
  • Member since Oct '09
« Reply #4 on: Jun 04, 2010, 07:22:04 PM »
They sell mount kits for them. That's what we did on my buddys first gen.
86 mini truck 18" rays
09 highlander
70 suburban
earfarmer
  • Member since Aug '10
« Reply #5 on: Aug 20, 2010, 07:45:07 AM »
Are there any common problems with this install?
joey0712
  • Male Posts: 1,459
  • Member since Apr '08
« Reply #6 on: Aug 20, 2010, 08:45:24 AM »
Not really just put the box as far forward as possiable and make sure the pitman clears.
91 Toyota High pinions f&r.
earfarmer
« Reply #7 on: Aug 20, 2010, 09:56:58 AM »
Thanks! :thumbs:
Last post Sep 29, 2003, 05:51:34 AM
by Bones
steering?
Last post Jan 16, 2004, 11:06:28 AM
by yotacrawler85
Last post Apr 01, 2004, 12:25:32 PM
by burl4x4
Last post Mar 23, 2004, 06:43:20 PM
by moutaintoys
Last post Apr 25, 2011, 02:49:15 AM
by Rocksurfer
