-fix n it-
Started by Gittinit, February 20, 2007, 06:13:13 PM
Gittinit
This content has been removed . Have a nice life.   :moon:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Gittinit
#1
my favorite places:
Gittinit
#2
my favorite places:
Gittinit
#3
my favorite places:
MiniSimp
Gittinit
#5
my favorite places:
Gittinit
#6
my favorite places:
Gittinit
#7
my favorite places:
Weld er up again, but more this time!
Gittinit
#9
my favorite places:
Gittinit
Quote from: Hyena on February 20, 2007, 07:04:02 PM
That was my thoughts too any suggestions?
my favorite places:
weld the gears together and then tothe carrier.  Weld each gear to the carrier and your gonna want the wleder up so it gets good penetration.  but i would weld one or two beads and then let it cool so it doesn't warp.
put a piece of 3/8  by 1 inch  plate  against the spider pin then weld that  into the spiders,   do that on both sides  and it wont break again
Gittinit
#13
my favorite places:
i wouldnt weld  the side gears to the carrier,  you about tripple your chance of carrier  warpage
hmmm, mine front and rear have been pretty good so far.  both have the spider gears welded to the carrier.  it is stronger.
boggerunner
i have been abusing my welded front and rear 3rd for 2 yrs and with no problems, and they are all melted to each other and to the carrier, once before i did try the plate ideal, and it was a bad ideal, it broke loose and destroyed the carrier and the spiders, everything fell apart and locked up, after getting it to unbing, i had to tow it home and lost me axle bearings since the spider gears all fell into pieces into the bottom of the housing
alwayzbroken
Mine is welded to the carrier. It could be warped but it hasn't broke.
Gittinit
#18
my favorite places:
Gittinit
I also removed the shock mounts and the spring perches to get ready for the new..... um.... You will have to find out later. :psss:   :haha:
my favorite places:
Gittinit
#20
my favorite places:
Gittinit
#21
my favorite places:
alwayzbroken
Nice work dude :yesnod: I like how that turned out. How long did it take?
Gittinit
#23
my favorite places:
Gittinit
#24
my favorite places:
alwayzbroken
You decided against the drive flanges then? Mine should arrive on Wednesday with my Arp hub and knuckle studs.
DTB
Quote from: gittinit on February 26, 2007, 04:48:52 PM
I almost forgot! I ordered a set of 30 spline longs with cromo hub gears! I also ordered a hydro cylinder from surplus center for assist steering.:woohoo:
SWEET!!!   :clap2: :clap2: :bowdown:
Gittinit
#27
my favorite places:
DTB
Quote from: gittinit on February 26, 2007, 05:23:02 PM
for just a few dollars more I had the option to unlock the hubs,
that is a very good option to have sometimes :yesnod: could possibly save your ass
alwayzbroken
Bobby woundn't warrenty the axles unless I bought his flanges, and for just a few dollars more I had the option to unlock the hubs, so..... what the heck!
I called him and he said it wouldn't be an issue since the drive flange material is softer than the birfield thus the drive flange will strip before the birf does. He also noted that drive flange failure was very uncommon. I would rather the drive flange strip than something else detonating in the drivetrain.
