There is info all over about this. Look around and all your questions will be answered. People don't like spoon feeding those who won't help themselves.
Sorry the natives are a little uptight for some reason, hope you can for give them for being asses. They should remmember they were once new here too.
E-brakes are not worth the added cost.
cool thanks for the info willy that sounds great i would love to go the route you did thats pretty much all the stuff i wanted to here if you could send me some demenshions on the brackets i can write up a program and i can have them milled out on the fadal at scool or just bridge port them thanks alot, john
I used an Isuzu 88-89 rear caliper and rotor on mine. I have templates for brackets if you are interested.
You will need banjo style brake lines to fit the calipers too and there is some machining needed to the axle to clear the rotor.
i went with the larger brak calipers and vented rotors on the front but the rear i just used a 86' + axle...IMO disc in the rear are not needed unless your running fourties.
Discs in the rear may not be needed unless you run in mud and like having no brakes and changing shoes after every weekend.
Ruffstuff specialties makes a braket for about 50.00 to put taco dics on the rear.http://www.ruffstuffspecialties.com/catalog/adapter-caliper-p-111.html
i love your sig your down to a half of a maverick
Started by GrenadedToy General 4WD Discussion
Started by KYOTA Toyota Pickup/4Runner Tech 1979-95
Started by NCK4L Toyota Pickup/4Runner Tech 1979-95
Started by i_luv_my_truck 1979-1983: How-To Guides
Started by Steve_925 « 1 2 » Parts For Sale
