Toyoda did in fact offer a 4.88 ring and pinion. The aren't as popular as the aftermarket r&p because they aren't easily found and Toyota is the only place to find replacements. I believe that the carrier and possibly the housings are different than other comparable 3rds. That particular 3remember in the 2nd pic by EricB is for a 8.4 taco axle and will not bolt into a 1st 2nd or 3rd gen Toyota.
to go with this i have read that several people said the housings aren't different at all, just the internals of the third, i think kyle_22r knows for sure
this site said otherwise? http://home.4x4wire.com/erik/diffs/Although somewhat rare, there is a version of this diff that came from the factory with 4.88 gears. The carrier (3rd member housing) has a different pinion offset so that the ring gear doesn't need to be as thick. This means that no gears other than the factory 4.88's will fit this particular diff. However, diff cases, commonly called carriers (factory, LSD, lockers, etc.), for the standard V6/Turbo diff should be interchangeable (4cyl and V6/Turbo carriers are NOT interchangeable).
according to that site, i was right... i said the internals of the third, not the third itself, i meant spiders/grears, and that the housings of those wierd 4.88 diffs were no different than a regular housing
The third member chunk is different. All v6 lockers would work. No option to regear unless third member chunk is replace. Little confusing as to what your refering to as a housing.
Started by 86yota General 4WD Discussion
Started by oddball Engine
Started by KDC Engine
Started by Destruct O General 4WD Discussion
Started by emsvitil Project Research and Build-Ups
