Well, the 22R that we have has a good head, and the guy we bought it from (four-wheeler and works for Toyota) said that we could use a 20R block with a 22R head, which, he said, would give us higher compression. Now I'm wondering if he had it backwards or can you also do it that way?Thanks Coyotefrg for the info.
Where are you at in Colorado and what gear ratio do you need? Is the front OK?
I'm in Boulder, CO. We just need the stock 4.10s. The front should work because we just need the ring and pinion and from what I understand they are interchangeable, right?Thanks Rocksurfer. Now we know not to look for a 20R block and just probably rebuild the 22R.
Started by oddball Engine
Started by Destruct O General 4WD Discussion
Started by robrub00 Engine
Started by 46&2 Toyota Pickup/4Runner Tech 1979-95
Started by Ozy General 4WD Discussion
