0 Members and 76 Guests are viewing this topic.
crap this one is scaryhttp://raleigh.craigslist.org/cto/970037232.htmlHowdy all. This has been my project truck for about 10 years now. If you have ever wanted to build a monster truck but didn't know where to start here is one that is almost ready to go. Here are some specs:Truck: 1986 Ford Bronco, Eddie Bauer edition 4x4 Cloth seatsMotor: 1978 460, fresh rebuild (less than 400 miles on it) * Bored .030 over with 1:9.5 compresion * RV Camshaft for stump-pulling torque * Crank ground .010/.010 with all fresh bearings * new lifters and rods * heads shaved and rebuilt * Ford Racing Aluminum valve covers * Edelbrock duel plane intake * Holly Carb * MSD Offroad electronic ignitionTransmission, C6 Fresh rebuild (less than 400 miles) * New clutch packs * valve body rebuilt with mild shift kit * RV torque converter for low lockupTransfercase, NP205 Fresh rebuild * all new bearings and seals * 1410 U-Joint on rear (never got one for the front but it is a bolt on)Axles 2.5 ton Military Rockwells * Hubs flipped front and rear * Bearings repacked * 1410 Ujoints front and rear * pinion shaft mounted disk brake in rear * comes with one Detroit locker (not installed)Suspention: * 19" of lift over stock total * 12" coil springs on 7" WELDED blocks * Triangulated four link in front * rear is welded blocks with stock leafs. * I reposistion the rear leafs underneth the frame for more flex and did a shackle flip. The rear needs a anti wrap bar fabricated Tires/Wheels * Wheels are military 2.5 ton 20" steel * Tires are 48" Michilin brand new retreded XLM'sOther Misc * I gutted the dash, it now has a custom aluminum panel dash with speedo, tach, oil/water/volt meter. It has a CD player and CB Radio installed in the dash. I replaced the factory speakers with aftermarket speakers (but no sub). The fuese box is on the outside of the dash, no more fumbling around upside down looking for bad fuses. * The motor has a onboard air compressor and a onboard welder (needs to be wired up) * 8,000 pound warn winch * Optima off-road batteryHere is what the truck needs to be finished:Front drive shaft; Has the rear one, just needs the frontSome work to the wiring; the battery wires have oxidixed and probably need replacing, sometimes it will start sometimes it won't, it is a wire problemRear anti wrap bar OR rear lift springs; whatever you want to do, but it will suffer from axle wrap bigtime as isreweld front four link brackets; Very simple operation, I just welded the brackets on to close togetherWelding shock mounts and installing shocksOverall this is a 95% done truck. I have invested (sunk) over 20K into it. It was very theriputic at the time, but I haven't serioulsy wrenched on it in about 4 years. Take her away for $5,500 and finish it off and enjoy it. This truck is located in Greenville, last time I was there it started up and I drove it around the storage place I keep it at. The truck runs and drives but isn't road legal and isn't ready for the trail/mud. If you are intrested please have 1) a tow rig and 2) access to a welder; you will need both. I am asking $5,500; I will entertain trades but I am not interested in boats or another project vehical.I live in Raleigh, the truck is in Greenville, E-mail me with any questions
http://peoria.craigslist.org/cto/978797480.html and description:http://peoria.craigslist.org/cto/978743405.html
Haha I actually saw a build up on pirate a few years ago where a guy was SASing a Chevy Astro van. Definitely not the vehicle I would want to dump a lot of money into, but he had a big family and needed to keep the minivan, so he did a build up on it. Actually did pretty good work, though I dont think this is the same one. Whatever floats your boat I admit I do like those ford straight axle 4wd vans. Always thought it would be kinda cool to have a mildly built one, kind of a camping or hunting rig. There was one in petersons a while back, it looked pretty sick for a van.
not a disgrace to off road but just toyota in general
i remember reading something on this thing its remote controlled on top of all that
NOw...that's pretty cool! Then no one gets hurt when it tips over
hahaha i found this on toyotaoffroad.com
Started by UNBREAKABLE Chit Chat Camp
Started by nowhitefenders Trail Reports, Events, and Gatherings
Started by iNfErNaL Trail Reports, Events, and Gatherings
Started by DTB « 1 2 ... 15 16 » Chit Chat Camp
Started by iNfErNaL « 1 2 3 4 » Chit Chat Camp
