go pull the tcase off your isuzu tranny and post picsIsuzu used GM parts ALOT, its very possible your old tranny could use a chevy S10 adapter to toyota tcase
What size is the Isuzu engine and what kind of power are we talking about anyway?Why not make it easy on your self and do a 22R swap or even a 3RZ. This way you could gain more power, shorten your drive line and skip all the adapter stuff.
a 3rz will let you keep efi
I have the 2.6 engine in the Amigo, and I would like to keep EFI. This is extremely helpful!!! http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB68&Number=485664I see I can use the A340-F, it bolts right up to the 2.6 bellhousing But not quite the budget here
if the 2.6 will bolt to a 340F then it should bolt to other toy trannies
I'll give TAP a call, I doubt they'll let the whole setup go for under $1k though.
I've been doin some asking around. It seems that the only Toyota transmissions that will bolt to the 2.6 bellhousing are automatics. And there ain't any aftermarket gears for em, so my solution would have to be stacked tcases with an adapter and that runs a pretty penny. I'm gonna look for the 22RE setup. In the meantime we're just gonna solid mount my engine/trans/tcase so that the rattling is minimized and the intermediate shaft can handle the setup.
:OH OH i was looking for some GMC parts today and found a early 80's Isuzu 4x4 pickup with the DEISELi can probably get the hole engine tranny and tcase for 200
Hmmm... would I have to worry bout smog, even though it's diesel and diesels in CA don't have to smog? I mean being a '93 and built as a gas vehicle, would I be able to register it here?
Started by rick80 Parts For Sale
Started by neliconcept Toyota Tacoma/4Runner/T100/Tundra/FJ Cruiser 1995+
Started by broke_okie Engine
Started by toyotajoe35 Parts For Sale
Started by xxOkieTacoxx Transmission/Clutch
