Author Topic: 20 head on 22 block ?  (Read 2100 times)
yotadork83
  • Turtle Points: 18
  • Male Posts: 705
  • Member since Mar '06
  • ninja turtules rule!!
« on: Nov 18, 2006, 05:29:48 PM »
i am looking for some pics of how people routed there heater hoses. never done this before and want to make sure that i do it right.
yotas 4 life homie!
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 20 head on 22 block ?
« Reply #1 on: Nov 18, 2006, 07:46:50 PM »
:thud:   i can get you some tomorrow,  if  my tooth dont start killing me again
but  basically the same as any 22R  that has the water heated intake
  • Turtle Points: 1128
  • Male Posts: 9,757
  • Member since Oct '04
« Reply #2 on: Nov 18, 2006, 10:18:07 PM »
These are all I could come up with.  Not sure if this helps at all, but It's currently a little cleaner and more exposed, so I can snap more pics tomorrow if glen doesn't get around to it.  I have a weber with a water choke also.
yotadork83 [OP]
  • Turtle Points: 18
  • Male Posts: 705
« Reply #3 on: Nov 19, 2006, 12:18:13 PM »
well i got it torn down and put togeter and then i rotated it to tdc so i could install the distributar and the motor stoped moving. so know i have to get different pistons to make it work. so pissed becuase i would of had it done in like 3 hours but know i am looking at a couple of weeks. i want to order .030 over pistons but which ones would would be the best for clearence.
yotas 4 life homie!
« Reply #4 on: Nov 25, 2006, 07:13:16 PM »
what you mean it quit  turning??
you uses a 80-84 22R block right??  if your cam was  installed  straight up  you shouldnt have any clearance issues at all,  unless you have one HECK of a cam
yotadork83 [OP]
  • Turtle Points: 18
  • Male Posts: 705
« Reply #5 on: Nov 26, 2006, 11:51:22 AM »
it stoped turning right at top dead center and when i pulled off the head the intake valves were hitting the the outer corner of the raised section of the piston.
yotas 4 life homie!
Last post Dec 13, 2006, 07:24:55 PM
by 79coyotefrg
Last post Jan 23, 2007, 08:43:42 PM
by 79coyotefrg
Last post Jul 04, 2010, 09:42:19 AM
by crazykooter
Last post Jun 20, 2011, 10:13:41 AM
by Zs Confederate Toy
Last post Mar 14, 2017, 08:46:30 AM
by SnailPowered3RZ
