New Pivot Block Design
Started by MiniSimp, October 26, 2006, 02:54:21 PM
MiniSimp
What do you guys think?
Any ways to improve?
MiniSimp
 :greengrin:
dune_it86
no  :bull crap: how much cuz i like'em
Gittinit
How much angle can you achive from the new design? They look like they cannot move as much as the old design. :headscratch:
my favorite places:
http://www.flatnasty.net/
http://www.orvpark.com/
Hottrod81
MiniSimp
First I saw them was on Formula Toy 27.
After that, I had Dave's Offroad build them for me.
Hottrod81
MiniSimp
Quote from: Hottrod81 on October 26, 2006, 04:56:40 PM
Do they actually help at all?
Ask Big Mike, he gained 11" of travel. :greengrin: They help.
Willy Mammoth
1. What size is the pivot bolt?
2. How tall is it from the axle flange to the spring?
3. How long is the center pivot hole?
4. What is holding the spring perch on the axle besides the factory weld that tears a hole in the axle?
MiniSimp
Quote from: Willy Mammoth on October 26, 2006, 05:19:08 PM
1. 3/4"
2. 2"
3. around 6"
4. Just the factory weld that tears a hole in the axle (will be reinforced upon installation)
The drawings are not to spec, it was just so I could get a visual on a new idea.
BUDDERS
I think a low profile rubber snubber on either side of the pivot would be a good idea.  It would help prevent funny noises and stress on the welds when under fully arched out.
IronClad
methinks a 7/8ths bolt would be alot better..  especially since its steel on steel..  any greasing ability ?  its a better design than the last thats for sure..
also i hope its not some welded together junk and they are actually machined pieces  otherwise  your strength is gone
Annihilation  Fabrication
Do you need a Hammer?
MiniSimp
it would have to be machined.
the bolt held up fine on the last set, it was the tubing that was the problem.
Willy Mammoth
The center pivot should be as long as possible to help stabilize the load and not over work the bolt and center pivot block.
3/4" should be fine if the center pivot is long enough.
It is the torquing of the axle that exerts excessive force on the bolt, so making that pivot spread out as much as possible will make it stronger.
alwayzbroken
I like it :biggthumpup: Find a machine shop and market them yourself on ebay if you want to make some cash. No joke you will make good money. I will buy a set if they hold up  :) I could probably be convinced to rip a hole in my axle testing them also...
Willy Mammoth
Something like this. (nice drawing huh)  :rofl2:
alwayzbroken
I am not even gonna attempt to draw but could wings be put off the side and trussed to the axle to increase the weld area for the perch? It is probaly impossible to know what I am thinking of without a picture. I also know that spring perches on 3rd gen rear axles are much more beefy than previous models and are boxed in from the factory. Too bad I just sold mine  :hammer:
alwayzbroken
All right here goes nothing
MiniSimp
That looks good, I'll draw it up tomorrow and get some specs on the flex.
Willy Mammoth
Quote from: alwayzbroken on October 26, 2006, 06:29:39 PM
You said you wern't going to try. :ha_ha:
You could just put a 1/4" x 2" flat bar strap around the axle and weld it to the perch. That will keep the perch from tearing loose.
alwayzbroken
That would do it.
Quote from: Willy Mammoth on October 26, 2006, 06:43:39 PM
I got a sudden surge of budweiser inspired ambition  :beerchug:
Willy Mammoth
alwayzbroken
How about this?  :laugh: :hahaha:
Hey Mini, that is pretty slick. I really like the addition made in reply #17 by alwayzbroken. You could make it replace the whole pirch all together even, but definately that side support would surly be a benifit.
I have not installed the new HD pivots yet, but I plan on doing it before the Hammers for Thanksgiving.
yotaboy79
what size and thickness was the tubing on the previose design ive been thinking about making a set and using 1 1/2 .250 wall dom and a 1" grade 8 bolt
MiniSimp
Ok, so this one would fit over the original perch and weld to the front and rear edges of the perch, and the housing it self.
28* pivot (which is way more than I have used on the current design)
yotadork83
what might a set of set me back? i was going to build them myself like that but dont realy have time.
yotas 4 life homie!
MiniSimp
Quote from: yotadork83 on October 27, 2006, 09:22:14 AM
Not sure, you can buy the stronger design right now from Dave's Offroad Outlet in Sonora.
MiniSimp
And with Mr W's axle strap
alwayzbroken
I like it. Find somebody to make it now.
