Author Topic: best electric fuel pump, need help.  (Read 5466 times)
kauaikid
  • Male Posts: 267
  • Member since Dec '04
« on: Oct 12, 2006, 07:27:52 AM »
I'm putting a weber 32/36 on my 84 and was looking for advice on what electric fuel pump to get and how hard is it to install.  Any advice would be great.  Thanks.
Ken
84 longbed, lc eng. top end kit, dual cases w/ 4.7 in rear, arb's front w/high pinion and rear with v6 diff., 5.29's w/ 35s, all-pro long travel 4" and much more
Re: best electric fuel pump, need help.
« Reply #1 on: Oct 12, 2006, 07:44:22 AM »
LCEngineering.com  has a great e pump,  but  any epump  thats designed for a carb ,   hi volume low pressure,   and put it close to the tank
4inchToyotas
  • Turtle Points: -260
  • Male Posts: 351
  • Wheeling does exist in the ATL
    • Georgia Cruisers
« Reply #2 on: Oct 12, 2006, 07:49:46 AM »
EDIE: i'd also suggest a pressure regulator but that's my  :twocents:
« Last Edit: Oct 12, 2006, 08:02:09 AM by 4inchToyotas »
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
kauaikid [OP]
  • Male Posts: 267
« Reply #3 on: Oct 12, 2006, 07:51:31 AM »
tell me more about pressure regulators.  How much, where to get one, does an 84 have one on it now, how hard to install?
4inchToyotas
  • Male Posts: 351
    • Georgia Cruisers
« Reply #4 on: Oct 12, 2006, 07:54:58 AM »
I've got one between the mech fuel pump and the weber. Got it from autozone (Mr. Gasket regulator I think) I think it was like 15-20 bux.?? So far no problems on hills or bouncing around.
« Reply #5 on: Oct 12, 2006, 08:04:25 AM »
for crawling  they are good,  but  for HP  they will decrease fuel delivery at high rpms,   but thats just me :disturbed:
4inchToyotas
  • Male Posts: 351
    • Georgia Cruisers
« Reply #6 on: Oct 12, 2006, 08:06:48 AM »
Ah, jes that does do the happening on mine, but it's designed for the crawling, and not the racing. Don't listen to me much, listen to 79C - he's da man
 :bowdown:
kauaikid [OP]
  • Male Posts: 267
« Reply #7 on: Oct 12, 2006, 08:20:35 AM »
thanks for the info.  I just called a shop here and they sell a rotary style pump for 100 bucks and said they give a countinous 5 psi and are much quieter than the 40 dollar facet pump.  He recomended running a pressure regulator but I plan on using this truck for daily driving do you still think I need one? Do you think 100 buck is to much for a fuel pump?  Have you heard of a rotary style pump he said they use them on 911 porsches, I called a VW shop.
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Member since May '05
  • Ouch My Eye!
« Reply #8 on: Oct 12, 2006, 08:26:31 AM »
To my understanding Weber's like low pressure correct?
Just signing up to the thread.
I like to Drive!
kauaikid [OP]
  • Male Posts: 267
« Reply #9 on: Oct 12, 2006, 08:30:22 AM »
that's what all the shops I've called and posts I've read states.  Somewhere between 4-5 psi.  I just called autozone and they got a bosch pump for 65 dollars, what about these?  Are they any good?
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #10 on: Oct 12, 2006, 08:41:08 AM »
That's what I thought.
I haven't heard anything about running the bosch in a yota for a weber. So Im not sure.  But when it comes to my VW I only buy bosch replacement parts.
I like to Drive!
kauaikid [OP]
  • Male Posts: 267
« Reply #11 on: Oct 12, 2006, 08:43:16 AM »
do you have a bosch fuel pump? Is it noisy? are you running it with a weber and if so is it working out for you? Thanks
Wermz84
  • Rock Nerd!
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #12 on: Oct 12, 2006, 10:20:02 AM »
My VW is all EFI.  That's why I'm not sure if it would work well here.
I like to Drive!
TRHS1980
  • Male Posts: 234
  • Member since Apr '06
« Reply #13 on: Oct 12, 2006, 10:40:50 AM »
I think for the weber 32/36 you need more like 2.5-3.5 psi... at least that what my weber manual said. Mines running about 3 right now, seems to be working good so far... here's the link to the regulator I got from summit.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HLY%2D12%2D804&N=700+400178+115&autoview=sku
2007 Tacoma 4x4 6-speed on 35's
"In all affairs it's a healthy thing now and then to hang a question mark on the things you have long taken for granted."
« Reply #14 on: Oct 12, 2006, 11:21:12 AM »
the bosch  is a good pump :thumbs:  the pump i have in the 79 tank is a bosch  and works great with my 32/36
4inchToyotas
  • Male Posts: 351
    • Georgia Cruisers
« Reply #15 on: Oct 12, 2006, 11:22:26 AM »
How did you block off the port for the mech pump?
mudmaster
  • Turtle Points: 3715
  • Male Posts: 2,854
« Reply #16 on: Oct 12, 2006, 11:24:30 AM »
I made my own plate
Time to go wheelin!
« Reply #17 on: Oct 12, 2006, 11:29:17 AM »
my 79  had a block off plate from the factory,   but  you can make one  easily  from some  3/16 or 1/4 inch plate
4inchToyotas
  • Male Posts: 351
    • Georgia Cruisers
« Reply #18 on: Oct 12, 2006, 11:30:15 AM »
I may actually have one somewhere, but I see now. If my mech pump ever goes out I'll go electric :shocking:
TRHS1980
  • Male Posts: 234
« Reply #19 on: Oct 12, 2006, 12:48:29 PM »
Maybe something obvious is escaping me, but why would you run electric fuel pump if you have a spot on the head for a mechanical? I know the mechanical tends to pulsate more, hence the pressure regulator, but is there another reason to go electric?
4inchToyotas
  • Male Posts: 351
    • Georgia Cruisers
« Reply #20 on: Oct 12, 2006, 04:16:12 PM »
Here's one showing the regulator
Last post Jul 23, 2006, 10:46:56 AM
by BUBBA
Last post Oct 28, 2006, 03:24:31 PM
by wildchild1066
Last post Apr 02, 2008, 08:35:42 PM
by 79coyotefrg
Last post Aug 20, 2013, 03:14:56 PM
by hunmetal
Last post Apr 28, 2016, 07:00:27 PM
by kneedownnate
