Most embarrassing break on the trail
Started by Blingn, October 04, 2006, 07:53:25 PM
Duffil
only time i've ever broken on the trail, I had mentioned how "i beat this thing and it just asks for more!"  and then my fuel pressure regulator died and I looked like an ass.
*** YELLER ***
Alrught here, before MINI post it.
wasnt the trail but it still sucked  :tantrum:
:usa: :beerwhack:
except BACON
Willy Mammoth
You gotta keep them lug nuts tight. :(
While I'm here let me share this one.
We were on a Jeep poker run and I was leading a group when the trail bottle necked into a section of woods where there was a lot of downed trees. I sent the others back around and I proceeded to make my way over the trees. After a few tries and almost getting high centered I decided to launch over them. after getting over and back to the trail  I found the front shackles had flipped and we had to hold up the groups progress to fix my screwup. Had I gone around like everybody else we may have been one of the first back to the meeting spot.
DAWGTOY
left my winch controler pluged in and on the floorboard.
was swiching tranfercase gears and my heel pushed in the
in button. kept hearing this whining noise from the cb and
thought WTF. sounded like my transfer gears. but the winch
kept tighting up till it blew out the side cover. :smack:
glad i diddnt need the winch the rest of the day.
stupid dawg
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
germ
Several years ago, a local club I was in went up to do Swamp Lake/Dusy. As we were headed through a fairly easy portion, we had to climb a small step of roots. My 72 'cruiser died. We fiddled with all sorts of differnet things trying to figure it out. Thought it was the carb, then the ignition. Nothing! Finally I jumped into a buddies Jeep, we wheeled all the way back to Shaver lake, found the Napa store, and bought everything we could think of for the ignition system...plugs, points, condenser, cap, rotor...the whole package. Nobody had a feeler guage, so we set the points using a matchbook cover. After doing all this, I jumped in and tried it...Nothing! As I threw my head back in total disgust, I looked up and realized that I'd somehow thrown the safety switch (antitheft) that I'd installed just a few days before and had completley forgotten about. I casually reached up, flipped the switch, and it started on the first try! I actually drove around with my points set by the matchbook cover for almost 2 years afterwards, 'cause it ran better than it ever did when using the feeler-guage.
Erik :usa:
boggerunner
my front drive shaft is too short, so i had to run this trail up in parachute called the battlements backwards to keep my front drive shaft from seperating, i made it up the mountin, but my neck really hurt, i put shocks on, and added a few inches, and no problems now.
I once lost my timing chain in the middle of 21 road, now that sucked
Tallchevy
Fordh8r & I were in Hollister  :thumbs: & my 4Runner was stock & still had IFS  :thumbdown:  Going up a flat trail I noticed that the left front tire had popped the bead  :thumbdown:  I put on a spare & continued up the trail. There was a spot were I had to climb out cause the rest of the trail was getting difficult. I couldn't get out so I continued up the trail with Fordh8r spotting me & he noticed the left front bead had popped off on the spare tire this time. I just changed it not even 10 minutes earlier  :smack:  Put another spare on & had to thrash to get out. Made it out & it was time to leave  :thumbdown: Went to air up & found that the right rear tire had dirt between the bead & rim  :smack:  Got one of the other tires to air up & changed that one this time. All this in 30 minutes!  :outtahere: Felt like I should have been on a pit crew for NASCAR!
87 4Runner redo
MCR5, was right above old sluice heading down and all four drivers side steering arm studs decided to sheer.  ended up stoping traffic for an good hour and half or so.  wouldn't have been so bad but the passenger side had broke the week before.
iNfErNaL
Okay,how'bout working on your rig for a week and getting out to the Hammers and breaking 1/3 of the way up SledgeHammer on the first night while wheelin' with a bunch of Toyotas?...Pretty damn embarrassing  :shake_head: .
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
boggerunner
Duffil
iNfErNaL
Quote from: boggerunner on January 17, 2007, 11:11:37 PM
its a jeep thing and we do understand
Thing is that none of the crap that broke is Jeep stuff,it's 1 ton crap.
boggerunner
but it is bolted to a jeep, its kinda like a virus.  It spreads to every limb and infects it.
iNfErNaL
Quote from: boggerunner on January 18, 2007, 09:36:30 AM
Ha Ha,very true.I'll be the first to admit that Jeeps are pieces of :pokinit:.
boggerunner
after that bein said, u must buy a tacoma, mabey the white tacoma of allpoo's that is a sweet truck, trade them the jeep for it
iNfErNaL
Quote from: boggerunner on January 18, 2007, 06:34:36 PM
Ha Ha,he ONLY wants $45K for it.
crawlerdan
ok ok , one time, at band camp...wait wrong forum
ok how bout this, about 5 years ago, when i wheeled a trplecased 85 yota, toybuilt and i got hit by a freak snowstorm on fordyce, got lost, i ran outa gas twice, my rear drivers tire came off due to loose nuts...and we ended up lost somewhere in nevada.
i had no doors, windows or windshield wipers. so i took toybuilts pass. side wiper, we all got inside our sleeping bags, and drove down the freeway home 90 miles inside our bags with holes cut in the bottom so we could work the pedals
boggerunner
you are only 40 thoudand short after trade in
iNfErNaL
Quote from: boggerunner on January 19, 2007, 01:06:11 PM
Allright,so are you trying to talk :pokinit: now?,either way let's STFU and get back on topic.
*FFC*
DTB
Quote from: crawlerdan on January 19, 2007, 09:17:31 AM
haha thats a good story! probably tops the others so far IMO
red
:rofl2: :rofl2: :rofl2: :rofl2: :worthless:
read and comment :whip:
USAF EOD tech
crawlerdan
