Pictures of 1st Generation 4Runners on 33's and 35's
Started by blackdiamond, October 01, 2006, 01:55:19 PM
blackdiamond
I'm looking for pictures of 1st Generation 4Runners running 33's and 35's along with details on the various lifts.
:snapshot:
My 86 IFS 33's, a simple lift of 2" body, Downey/Rancho A-arm kit which had everything needed to beef up the IFS to withstand even the toughest trails. The only other thing I did was to put lockers and 4.88's in the diffs. Picture quality may be poor, I took them off a video disc.
Here's my brother's on 35's 87 IFS with the same stuff except he did 3" body, and put a Pro comp lift on the front, he did use the Rancho/Downey kit too, just combined the good from both.
blackdiamond
Thanks  :biggthumpup:
What does your brother think of 35's with 4.88 gears?
Anybody have 35's and SAS?
madhunt
85 with 3" body 3" front springs 4" block in back i sit level with the 35's bearly rub during full lock i now run 33 wore out the 35's nu rub at all w/33's i run 4.88 gears detroit in back open if front, go where ever you want.
HIGH AND TIGHT OFFROAD
All_Set
35" MTR's, 4 or 5" all pooooos,  63 chevys in the back with shackles to match the front lift, no BL.
KDC
blackdiamond
86turboyota
1986, all pro 5in sas, 63" chevys 4" lift blocks, with dual shackles, 2" body lift, 35s
even with the body lift the tires still hit...
My Build 1986 4runner SAS 36s etc
http://board.marlincrawler.com/index.php?topic=22625.0
"Later, I learned that even though I engage 4WD my hubs are not automatically locking? Something about manual locking hubs I think. What's manual mean? I need to read a manual to lock them? lol  So I found these neat autolocking hubs and installed them. Sometimes they dont stay locked while I am backing up, but that's fine because I dont have a backup camera to see where Im going (like our RV) so I just simply dont ever back up"- BigMike
motorider228
blackdiamond
Quote from: motorider228 on October 03, 2006, 01:25:40 PM
are you looking to get a runner black diamond?
I will probably start hunting sometime in the next year.  The budget doesn't support a 4Runner quite yet, but it is in the works...currently #2 on the list.
CTENG in KS
Shoyrtt
85 on Marlin's 4" kit. 35 MTRs. 5.29s 8) No body lift. :nonono:
http://www.sharetrails.org/
motorider228
blackdiamond
Quote from: motorider228 on October 03, 2006, 08:49:50 PM
are you going to sell the truck BD?
I suspect the truck minus the transfer case, heavy duty cross member, front axle assembly, rear 3rd and a few other parts will likely get sold.
GrimReaper
33x12.5x15 on 15x7 stock offset rims.......NO LIFT. No Rub
The trick is the offset being stock. Hammered the pinch weld flat to the body mount and trimmed off the bottom few inches of the liner.
Hottrod81
bntracing7
85 4runner red bumpers......
http://www.myspace.com/rideredd7
bmxanddie
heres mine   2inch BL    33's
toyotagod69
All nice I would like to get a 4 runner someday.....
blackdiamond
I might be getting an 89 real soon.  I'm thinking SAS and 4.5 inch Alcan springs with 33's for now and upsized to 35's in the future.
fullsizenomore
I like what the gentleman did with hacking up a hardtop and turning it into a makeshift bikini top,pretty slick dude.
