Author Topic: How do I get the Axelshaft Out? (Urgent!)  (Read 1459 times)
82rustbeast
  • Turtle Points: 318
  • Male Posts: 500
« on: Sep 20, 2006, 05:38:20 PM »
I pulled an axelshaft out of a 91 Pickup rear housing.  I read that your sposed to just push the shaft out of the brake backing plate after you remove the snap ring. I did it but the shaft still wont come out. Do you have to pull out the bearing retainer or what. Help...again
Prismo
  • Turtle Points: 8403
  • Member since Oct '03
  • Living in the green house
Re: How do I get the Axelshaft Out? (Urgent!)
« Reply #1 on: Sep 20, 2006, 06:07:26 PM »
I believe the retainer & bearing must be removed for the backing plate to come off.
82rustbeast [OP]
  • Male Posts: 500
« Reply #2 on: Sep 20, 2006, 06:19:26 PM »
So how do you move the bearing retainer without damaging it. Im gonna need to reuse it
Prismo
« Reply #3 on: Sep 20, 2006, 06:37:19 PM »
I have never tried to re-use one. I would imagine the colder you can get the piece , the easier it will come off. If you have access to a press it wouldn't be to hard to get off. Maybe using a spitter type bearing puller & a plastic hammer might work if you don't.  I have always used a die grinder & a cutoff wheel to cut almost to the axle shaft & then a chisel to split the piece. I knock the new bearing & retainer on with a big piece of pipe. I heat the retainer in the oven to make it easier to install.
CTENG in KS
  • Turtle Points: -501
  • Male Posts: 4,295
  • Member since Jun '04
  • ^Alfred the Great
    • CTENG's Eco-Rant
Prismo
« Reply #5 on: Sep 20, 2006, 07:18:01 PM »
I would use a wood block instead of the concrete. How you doing CTENG?
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #6 on: Sep 20, 2006, 08:55:50 PM »
The axle shaft does not just hammer out of the backing plate after the snap ring is removed, [unless the axle is wasted].
It must be a press fit....
Many years ago, i made my own puller by cutting off the end of a rear axle tube and welding it to a 1/2 by 6" wide steel plate with a matching hole for the axle to pass thur.
After bolting the axle and backing plate to the press jig, I mount it in my 40 ton press and press away.
Sorry, but I have never been able to get it apart with a hammer.
Last post Dec 02, 2002, 02:39:27 PM
by toyotaboy
Last post Mar 04, 2004, 10:34:19 AM
by 84runner
Last post Oct 03, 2020, 11:15:37 PM
by itsatoy
Last post Nov 02, 2009, 08:21:35 PM
by germ
Last post Jul 28, 2017, 11:15:32 AM
by Misfit4Runner
