Author Topic: Mystery Part. Help!!  (Read 4681 times)
82rustbeast
  • Turtle Points: 318
  • Male Posts: 500
  • Member since Sep '05
« on: Sep 18, 2006, 02:31:10 PM »
What is this thing. Its in an 82 Toy shortbed. Its only connected to two wire in my truck. I think they're both black w/ red stripes
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: Mystery Part. Help!!
« Reply #1 on: Sep 18, 2006, 02:34:33 PM »
its a temp sensor of some type
*FFC*
  • Platinum Turtle Award
  • Internet Lassies
  • Turtle Points: 11
  • Female Posts: 8,265
  • Member since May '04
  • ~*Moderator*~
    • Buy me some coffee
« Reply #2 on: Sep 18, 2006, 02:38:49 PM »
Where was it located?
Shamb
  • Raisin in the making..
  • Turtle Points: 133
  • Male Posts: 3,414
  • Member since Oct '04
  • Proud Parent
« Reply #3 on: Sep 18, 2006, 02:43:20 PM »
almost looks like the sensor for your backup (reverse) lights that screws into the t-case.
but it would help if you posted where you pulled it from.
« Reply #4 on: Sep 18, 2006, 03:03:48 PM »
thats what it is
boggerunner
  • Turtle Points: 9
  • Male Posts: 3,140
  • Member since May '06
  • Philberbuilt
« Reply #5 on: Sep 18, 2006, 04:14:37 PM »
it could also be the brake pedal sensor or clutch pedal or e-brake sensor?
82rustbeast [OP]
  • Male Posts: 500
« Reply #6 on: Sep 18, 2006, 06:31:44 PM »
It was never connected to anything. Well when I bought the truck it was sitting on the passenger floorboard with the wires connected to it. Whenever my truck has any power. The backup lights come on. I noticed a llittle farther down the wire, theres a rubber grommit, so it must lead to something outside the cab so it might connect to the tranfer case for the light assembly. Theres a grommit missing from the rear of the cab at the bottem corner. Thanks for the input guys
« Reply #7 on: Sep 18, 2006, 06:50:42 PM »
yep,  tcase  4x4 light switch
82rustbeast [OP]
  • Male Posts: 500
« Reply #8 on: Sep 18, 2006, 06:53:03 PM »
alright, thanks i'll try it tomorrow cus my trucks not here. My 4wd light doesnt come on even in 4wd
unclejpl4x4
  • Turtle Points: 348
  • Male Posts: 3,522
  • Member since Apr '05
  • Broke & rusted
    • myspace
« Reply #9 on: Sep 18, 2006, 06:54:53 PM »
Thats the secret nitro butten  :burnout:
Shamb
  • Male Posts: 3,414
  • Proud Parent
« Reply #10 on: Sep 18, 2006, 07:27:18 PM »
if you look on the passenger side of the t-case around where the speedo cable screws in you'll see it.
Marlin
  • Inspirational Genius
  • Turtle Points: 138
  • Male Posts: 856
  • Member since Sep '02
  • MC³ = 1,148:1
    • Marlin Crawler
« Reply #11 on: Sep 18, 2006, 10:27:26 PM »
It is NOT the t-case switch.
All t-case 4 wd switches will always have a pig tail.
It does look like a back up light switch on a L43, or W50 transmission.
It appears to have a 14x1.50 mm thread.
Could be the E-brake light switch?
This switch is normaly open, so if your back up lights are on, the wires under the truck must be connected togeather.
The back up light switch is located on the top of your 82 L45 or L50 trans.
82rustbeast [OP]
  • Male Posts: 500
« Reply #12 on: Oct 11, 2006, 08:50:09 AM »
I checked ot the plug again, I was wrong. I meant it was connected to two wires, one was red w/black stripe, and red w/blue stripe. I got it to where my backup lights came on and then I depressed the switch and had something hold it there. And w/the switch pressed the backup lights turn off so it does have something to do with the back up lights. I have an  L45 tranny, its a 4 spd. All I see comind out of the t-case is the speed sensor thing, anymore held would be great! Thanks
Shamb
  • Male Posts: 3,414
  • Proud Parent
« Reply #13 on: Oct 11, 2006, 10:47:09 AM »
yea its just a reverse light switch.
when your transmission shifts into reverse it sets a signal through those wires which tells the reverse lights to come on.
82rustbeast [OP]
  • Male Posts: 500
« Reply #14 on: Oct 12, 2006, 12:41:30 PM »
Can someone show me a pic of where it screws into. I dont have any available holes for it.
  • Turtle Points: 2872
  • Male Posts: 8,707
« Reply #15 on: Oct 12, 2006, 12:45:37 PM »
if you look on the tranny page on marlins site you might be able to find it
  • Turtle Points: 1128
  • Male Posts: 9,757
« Reply #16 on: Oct 12, 2006, 07:17:35 PM »
On this pic it's just below the shift rail on the side of the tranny.
http://www.marlincrawler.com/images/l43r_500.jpg
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Member since Jul '04
  • Lego Enforcement
    • Spinnin4s 4x4 Club
« Reply #17 on: Oct 12, 2006, 07:21:41 PM »
Just hold it closed until you want to back up and then let it go. :hammer:
yotaboy79
  • stuck in the shop
  • Turtle Points: -19
  • Male Posts: 2,838
  • Member since Aug '03
« Reply #18 on: Oct 12, 2006, 07:27:33 PM »
if you still have the original tranny in the truck then that picture is not accurate. if it has the original tranny then the reverse light switch will be at the drivers side of the tranny at the top you wont be able to see it from under neath or from the sides your best bed is to pull the shifter boot and you might be able to get to it good luck
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
« Reply #19 on: Oct 12, 2006, 07:33:26 PM »
this is where it would be if the po didnt swap the tranny but the switch does look like the ones from the 79-80 tranny which might be why its not connected he could of swapped a newer tranny in and discoverd it didnt work
82rustbeast [OP]
  • Male Posts: 500
« Reply #20 on: Oct 12, 2006, 10:29:56 PM »
Yeah, I do have something in that hole connected to a pigtail like that.  In the same spot. I thought my truck wasnt an SR5 cus the gage cluster was messed up (the one without the tach). So I swapped in an SR5 tach whichI dint have to rewire anything. Plus a lot of things were dissconnected when I bought it so I've come to the assumption that it was a beater/parts truck. I'm thinking the tranny was swapped out before. So i'll try it tomorrow. I do have the shifter boot off so I can see where the switch goes. but the "Mystery Part" doesnt have a pigtail connector. From the switch, it goes straight to the main cab wiring. Plus it has grease and grime on it like it was outside of the cab. So I'll figure it out. Rhanks for all of the help youve all provided me with. :thumbs:
rednk1980
  • Male Posts: 1,295
  • Member since Mar '06
  • Pull Your Panties to the side!
« Reply #21 on: Oct 12, 2006, 10:59:09 PM »
I took mine out and ran it to a switch in my dash so i could have back-up lights. just another option.  :dunno:
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
« Reply #22 on: Oct 13, 2006, 06:34:21 PM »
ok the switch you showed a picture of is for a 79-80 4 speed but your truck had a newer tranny swapped in corect so thats why the the wiring doest match what you need to do is cut the wires going into the old style switch then get a plug that matches the one on the pigtail for the newer style switch or get a whole new plug set and rewire both i dont think the old style switch will work i think there will be clearance problems between the tranny tunnal and the switch  i dunno if that makes sense but good luck
82rustbeast [OP]
  • Male Posts: 500
« Reply #23 on: Oct 13, 2006, 09:56:19 PM »
You know, yotaboy79, your right, I never thought about trying to rewire it. I'll do that on monday. Truck isnt at my house. But I dont really understand why I have a connector to a 79-80 pickup, This makes me wonder if pretty much everything was switched in this truck cus the plate says its an 82. Thanks for the input
yotaboy79
  • stuck in the shop
  • Male Posts: 2,838
« Reply #24 on: Oct 13, 2006, 11:24:05 PM »
oh for some reason i thaught the truck was a 79 or 80 :smack: it could of just been that the switch went bad in the tranny and they got the wrong replacement and never put it in?
Last post Jun 14, 2008, 09:53:24 AM
by Dr.Maxwe001
Last post Nov 05, 2009, 07:02:57 PM
by JoeWelder
Last post May 08, 2012, 03:24:13 PM
by nisota
Last post Oct 17, 2012, 09:30:51 PM
by BigMike
Last post Nov 28, 2013, 10:02:32 AM
by rcks4me
