Author Topic: 63in springs installed. but!  (Read 2579 times)
toyman2
  • Member since Jun '04
« on: Sep 08, 2006, 09:23:59 PM »
i did what the FAQ sayed and all that,i also read as much as i could about them.
i went to flex them out and they dont even tighten the stock rear break line.
i have 8in eye to eye shackles moved 4in back,marlin U-bolt flip and 31/2X31/2X1/4 front mounts moved 11in foward.
any ideas, i wont do a double shackle.
what do you think?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: 63in springs installed. but!
« Reply #1 on: Sep 09, 2006, 12:40:53 PM »
:worthless:
your rear shackles need to angle  from the frame to the end of the springs  \  so  they look as thow  they would act as a ramp to jump over the cab of the truck,  does that make sense??   DO NOT TIGHTEN THE SHACKLE BOLTS TIGHT
toyman2 [OP]
« Reply #2 on: Sep 09, 2006, 02:10:06 PM »
yea they have pretty good angle  and i also no about the bolts being to tight ive checked all that
dune_it86
  • Male Posts: 323
  • Member since Oct '05
  • Toyfanatic
« Reply #3 on: Sep 09, 2006, 04:44:02 PM »
have you removed the overload spring yet
toyman2 [OP]
« Reply #4 on: Sep 09, 2006, 10:24:23 PM »
if i do what do i do for lift
fabtoys
  • Turtle Points: -6
  • Male Posts: 160
  • Member since Feb '05
« Reply #5 on: Sep 10, 2006, 08:06:37 AM »
 the overload is flat no lift involved maybe just 1/4 -1/2 "for the thickness of the overload
If its smooth your airborne
06 f550 4x4 crewcab w/ 3 buggy hauler
06 rhino 660
86 excab d44 d60 38 tslsx
90hp banshee
toyman2 [OP]
« Reply #6 on: Sep 10, 2006, 08:48:14 AM »
my comp.stops ok but the drop is the big deal.
its the main leaf im not even getting tight to the spring clamps
« Reply #7 on: Sep 10, 2006, 08:49:43 AM »
you didnt use leaves from a 3/4 ton chevy did you :aaa:
toyman2 [OP]
« Reply #8 on: Sep 11, 2006, 05:57:20 AM »
no,  i may have pre judged a bit.
i can get a tire about 36in in the air, im going to run them for a bit and see how they do
Crawler677
  • Turtle Points: -43
  • Male Posts: 324
  • BRRAaappp!
« Reply #9 on: Sep 11, 2006, 08:30:20 AM »
were these new springs or did you get them used?  if they are new then it is possible that they just need to be broken in.
toyman2 [OP]
« Reply #10 on: Sep 11, 2006, 07:08:09 PM »
they were out of a wrecking yard so i dont know how used
toyspider81
  • Male Posts: 161
  • Member since Jun '06
  • 81 Toyota "The Spider"
« Reply #11 on: Sep 13, 2006, 01:13:07 PM »
i have the same problem in the rear bro my shakels are long in the rear and im afraied that they will bind to one side or the other. so im going to run the MARLIN 4" out back. in less i can get a deal on 4 link for the rear.
RUN IT!!!
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Full Trucker Effect
« Reply #12 on: Sep 13, 2006, 01:34:48 PM »
Marlin 4" springs are the only way to go.  I had 63" Chevy's out back and they were unstable.
toyspider81
  • Male Posts: 161
« Reply #13 on: Sep 13, 2006, 07:19:17 PM »
yea i think your right cause my rear is verey unstable i almost don't want to drive it but i gotta drive it i love that bad boy. id like to see some pics of the marlin 4" rear flexed up. My front end is off the hook so if anyone has pics post'em
RUN IT!!!
toyman2 [OP]
« Reply #14 on: Sep 17, 2006, 09:11:54 PM »
ttt
Last post Jul 17, 2005, 02:06:49 PM
by Hylander
Last post May 13, 2009, 10:43:03 AM
by freds40
Last post Dec 31, 2011, 08:31:42 PM
by UndefinedTaco
Last post Feb 05, 2012, 08:40:34 PM
by Dingman.
Last post Aug 25, 2012, 06:35:18 PM
by CrawlerBrennan
