loud clunking
Started by GoaT, August 20, 2006, 08:50:03 AM
GoaT
i was driving my truck last night. i went over a set of train tracks, not too agressive or anything. but  a loud clunking has started im my rear axel, as my truck rolls. like every one tire rotation.
i see the drive shaft kick a lil but not alot. and the clunking come and goes.
i have 5.29s and its welded in the rear
what could be the prob? i replaced the pinion seal not to long ago, maby that bolt came loose? im about to tear in down.i just needed some guidence.
was this track crossing  at a "crossing"  if not you probably crushed the crush sleeve
GoaT
crush sleeve? like i just drove over it like all the rest of the cars. i wasnt off roading
Duffil
pull the driveshaft and check the torque on the pinion nut.
pinion nut :yesnod:   then check all U joints
GoaT
keep brain storming for me. i cant work on it till an hour or so.
thanks guys.
but whats a crush sleeve?
Duffil
it slides on the pinion and crushes down, maintaining proper preload.  Sometimes this is replaced with a solid pinion spacer.  looks like a top hat here:
its the only weak link of a toy diff,   the only  good way to go is a solid spacer
Quote from: 79Coyotefrg on August 20, 2006, 09:14:04 AM
haha, not relly the only weal link.  you might have busted a tooth off of one of the gears.
GoaT
was a crush sleeve something i needed to change when i did the pinion seal?
well it needs to be done when the third is on the bench
GoaT
Quote from: 79Coyotefrg on August 20, 2006, 10:38:43 AM
well i hope it was already...
well the pinion bolt only tighened about a 1/8 turn maby less. this sucks i really dont want to tear the 3rd out. i guess ill have to run a stock 3rd. its gonna be a turd to drive tho...
GoaT
weel my axle is in the air. the clunk is every one tire rotation. same spot every time. is it a tooth?
GoaT
remember this is my daly driver. i have no other car...
olivedrab85
Pull the drain plug if you broke a tooth you'll know.
"Gotta keep it G rated for Marlin"   my runner http://board.marlincrawler.com/index.php?topic=26527.0
rebelKrawler83
if theres a crap load of metal shaving that come out then yeah you know a tooth is busted off. you said it was welded in the rear right???
[><]YOTERBOY[><] WHEN IN DOUBT THROTTLE OUT
http://board.marlincrawler.com/index.php?topic=38804.0
you'll have a chunk come out
my guess from what you said,  broke ring gear
i have that complete 86 wide rear for sale $100
what gear ratio do you have??
rebelKrawler83
there we go that would solve the problem haha
GoaT
k a lil chunk of weld broke off.. jammed up on the inside of the ring gear. so it would clunk everytime the pinion gear passes over it..
GoaT
i have cleared it. spinns fine and gears look good...
but. do i take it to be re welded? od get rid of is and put a locker. haha if i can get the money to do it..
5.29s
rebelKrawler83
pretty sure it would make that noise happen, hopefully it didnt mess up any of the other teeth
GoaT
it was a small peice. no bigger then a ball bering. 3/16 by 3/16...
rebelKrawler83
but the rest of the gear teeth and stuff are ok?
GoaT
everything looks great.. just that lil piece of missing weld worries me
chances are good  it DID  mess a tooth up,  and if it broke loose  the next time you go around a corner in town it could explode
get that out of there and put a open or locker init
i would run a spool befor i welded one
rebelKrawler83
yeah i agree get rid of the welded one cuz if it explodes your screwed and yea id get a spool cuz there cheap so yeah
