Author Topic: NOISE FOR THE REAR?  (Read 2813 times)
854RUN
  • Turtle Points: 30
  • Male Posts: 890
  • Member since Mar '06
  • 4WHEEL 4EVER
NOISE FOR THE REAR?
« on: Aug 18, 2006, 07:44:43 AM »
OK so my rear was making noise (loud vibrating noise  :yikes: ) between the drive and cost side of the gears. There was no noise if i kept seedy pressure on the gears (keeping on the gas). So new gears were installed buy a pro and the noise old gears are not in bad shape thou. the noise is still there just not a bad. So would a unbalanced drive shaft cose this noise or t-cases (turbo cases)? The rear is a Detroit with Yukon 5.29.  :dunno:  :headscratch: any thoughts?  :help:
-JOSH-
Re: NOISE FOR THE REAR?
« Reply #1 on: Aug 18, 2006, 08:30:12 AM »
sounds like you driveshaft is out of phase,  if it is the diff,  you need to find a "pro" that knows what the heck he's doing
854RUN [OP]
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #2 on: Aug 18, 2006, 08:40:49 AM »
LOL, ya i hope it the drivshaft and not the diff. The guy that did the install has done a lot of toys and has never had a problem with them ( i know a cupale of the guys) so i needed a reason to beef up the rear shaft so off to the steel yard for some new tube then some welding then to get it balanced. O-ya and the drivshaft now is stock but i shortened it after putting the dual Cases and never got it balanced.  :thumbs:
-JOSH-
toynorcal
  • Turtle Points: 96
  • Male Posts: 435
  • Member since Jul '05
  • "Easyline"
« Reply #3 on: Aug 18, 2006, 11:54:49 AM »
Here is a recent thread Marlin answered about this same type of problem...http://board.marlincrawler.com/index.php?topic=26380.msg283235#msg283235
You could also be looking at drive shaft angle or if you think it is comming from the Diff. then you may want to make sure the pinion nut isn't loose.
Good luck bud
Prismo
  • Turtle Points: 8484
  • Member since Oct '03
  • Living in the green house
« Reply #4 on: Aug 18, 2006, 11:59:31 AM »
Check your rear output. The bearing on mine went bad. I would highly recommend spacers instead of the crush sleeve when running a Detroit also.
854RUN [OP]
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #5 on: Aug 22, 2006, 10:31:37 AM »
toynorcal, the drive shaft angle is good but, i will check the pinion nut and make sure it cranked down to like 200ft-lb. :thumbs:
prismo, the bearings all have about 50 miles on them so they should be good  :crossed: and i did use a spacer instead of a crush sleeve so we will see and i am building a new drive shaft, new u-joints and getting it balanced. my drive shaft is not balanced at this time and the splines are pulled apart a Little to far some we will see.  :crossed: :crossed:
thanks guys i will keep you all updated  :biggthumpup:
-JOSH-
  • Shoutbox Moderator
  • Male Posts: 7,110
  • Member since Nov '05
« Reply #6 on: Aug 22, 2006, 10:45:13 AM »
OK so my rear was making noise (loud vibrating noise  :yikes::help:
:fart: sorry i had to hehehe :fart:
yota-tota
  • Turtle Points: 17
  • Male Posts: 232
  • Crawling over Marlin
« Reply #7 on: Aug 22, 2006, 01:58:03 PM »
i didn't know that the drive shaft being outta phase would cause bad vibes/noise. I think mine is out 45* since i swapped in my welded third.....that could be what i'm hearing and not my gears about to blow.
91 toy truggy on h2 injection, hacked n chopped n locked n SAS'd rolling 36" IROKS........doubler comming soon
All_Set
  • Turtle Points: -145
  • Male Posts: 543
  • Member since Mar '04
    • Blue Ribbon Coalition
« Reply #8 on: Aug 22, 2006, 02:24:52 PM »
Absolutely.  My phase was off 90 and it caused vibes over 55mph.  Corrected it and now no vibes at all.
854RUN why don't you check and see if your current drive shaft is out of phase?  I know your making a new shaft anyways, but check and report back.
Hottrod81
  • Turtle Points: -2
  • Male Posts: 1,392
  • Full Trucker Effect
« Reply #9 on: Aug 22, 2006, 02:36:33 PM »
I have had my driveshaft out of phase and the vibration is unbearable.
854RUN [OP]
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #10 on: Aug 22, 2006, 02:59:06 PM »
Ya it definitely sounds like my gears were about to blow
i will and i will let y'all know
-JOSH-
854RUN [OP]
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #11 on: Aug 22, 2006, 04:14:30 PM »
OK it is out of phase by like 2 splines. I assume that is enough  :dunno: I will do a better job this time lining up the u-joints before i weld  :hammer:. So how knows the inside diameter of tube i need for the new shaft?
-JOSH-
crawlerdan
  • Turtle Points: 1319
  • Male Posts: 4,770
« Reply #12 on: Aug 22, 2006, 04:22:08 PM »
all my yotas with cases have done this (5 ) and the fix for all of them was a cv in the rear shaft, and making sure that the driveline is at the right angles. the noise is cased by the cases amplifying the noise and vibration in the drive line and the rear output bearing
on a side note...whenever there is noise in my rear end, my wife tells me to go sit on the pot :haha:
854RUN [OP]
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #13 on: Aug 22, 2006, 10:05:21 PM »
:rofl2: :rofl2: :rofl2:
YA i talked to Steve a the shop to day and he said a lot of guys use front d-shafts so i think i am going to use a spear front drive shaft i have and extended it for the rear. :crossed:
« Last Edit: Aug 23, 2006, 06:09:11 AM by 854RUN »
-JOSH-
854RUN [OP]
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #14 on: Aug 29, 2006, 06:54:41 AM »
:driving: :burnout: :burnout:  :beer:  :beer: OK so i spent about $475.00 for new gears, install kit, and to have the installed which yall already know. Well it turns out that it was money well wasted because it was the drive shaft all along  :smack: well live and learn. So i took a front drive shaft i had laying around (cv :biggthumpup:) and had the tube beefed upped and lengthened to fit the 40" gap in the rear. well i put it on last night and took it for a spin 40mph, 50mph, 60, 70, 80, 85mph and no noise and no vibes and it only cost me $120.00. That should have been done first  :smack: :smack:. Thanks for all yalls help :beer:  :beerchug: :beerchug:
-JOSH-
toynorcal
  • Turtle Points: 96
  • Male Posts: 435
  • "Easyline"
« Reply #15 on: Aug 29, 2006, 07:33:15 AM »
Glad you got it fixed man  :thumbs:
abriel68
  • Member since Feb '07
  • 85 4runner
« Reply #16 on: Sep 28, 2008, 07:31:13 PM »
i had a question, its similiar to this problem, i have a spool with 5.29's in the rear third and i just recently got this very BAD noise coming from my drive shaft, i've never had a problem with my drive shaft, looks like the joints on the short end of the shaft are rubbing??? it confused the crap out of me, i took it apart put it back together im thinking it has the be the cross slipping back and forth causing the joints to rub but its a very bad rub and is rubbing the metal off each other, i parked my truck cuz its un bearable listenin to that. i've never had problems with the angle of my drive shaft either, if i can get some help that would be great,
854RUN [OP]
  • Turtle Points: 30
  • Male Posts: 890
  • 4WHEEL 4EVER
« Reply #17 on: Sep 29, 2008, 06:42:30 AM »
So 12" of lift, are you in Hawaii?? Anyways so if i under stand you right your u-joint caps? are moving in the yoke?? If so i would get a new joint (don't cheap out get one from toyota) and see if that fixes it if you put the joint in and it moves around still i would look for a other yoke. make sure your d-shaft is in "phase": http://www.pirate4x4.com/tech/billavista/PR-shaft/index2.html
-JOSH-
Last post Sep 15, 2006, 01:43:53 PM
by mado13
Last post Jun 01, 2007, 05:50:17 PM
by Yota Up
Last post Mar 04, 2009, 06:46:34 PM
by pumkin toy
Last post Dec 08, 2011, 10:05:31 AM
by 79coyotefrg
Last post Nov 08, 2011, 11:49:13 AM
by skipnrocks
