easy mods to do to a 1983 yota
Started by rebelKrawler83, August 13, 2006, 09:23:24 AM
rebelKrawler83
 :help: :dunno: yeah i need as much help as i can get on mods to do to my truck to get it better and stuff so if anyone is willin to help me out id really apreciate it :thumbs:
[><]YOTERBOY[><] WHEN IN DOUBT THROTTLE OUT
http://board.marlincrawler.com/index.php?topic=38804.0
Shamb
thats a pretty vague question, lets get a little background first. What have you already done to your truck?  what are you intensions for the truck?  what kind of trails do you like to take your truck on?  mud? rock? snow? dirt roads??
Answer those questions and i'm sure we can point you in the right direction.
Lockers, lift, tires, diff gears, t-case gears, Armor.
Vague.
he's from AZ  so  i cant see him in the snow much
rebelKrawler83
whops yeah that might of helped haha. well right now ive got a 3 inch body lift and 33 inch tires and thats really about it. and my intensions are to turn it into a hardcore crawler. so yeah
um ok,  well depending on the kind of body lift you have  you could  hold with that, BUT   with rock crawlin you dont want alot of body lift because of the body shift 2 inches max  unless the lift blocks  are large diameter
i am making myself some 1 inch blocks  but they are 4 x 5 inches  to spread the load around on the bottom of the cab
find some 86-93  F150  springs at the junk yard,  then  use 1 leaf  for each corner of your truck,  you will get lift, about 3 inches  and gain FLEX
then spend some :bling:  on a rear locker  and then a winch
rebelKrawler83
ight sounds good anybody have some other keep little ideas and wat size pipe should i use for the exo cage and sliders and stuff
Shamb
I used  1 1/4" tube for my exo, looks nice. .. not to bulky.
What input you get for a "hardcore rock crawler" is going to be really wide spread because everyone has their own opinion on what that is..
If you live in AZ and plan on hitting the harder trails i'd say atleast a 37" tire, 4 or 5" spring lift, ditch the bodylift all together... get some lockers in the front and rear, regear the axles to 5.29's and get some mod's to the t-case.. either a 4.7 gear reduction or dual transfer cases are ideal w/ more options.
Just a vague overview of a nice build that would be humble enough to tackle most trails, obviously you can elaborate a bit more with 30 spline axle shafts, what type of lockers, lifts, tires, gears ect... do a little research and check out some other guys builds in the Buildup section. You'll be suprised what you learn!
4inchToyotas
AND DON'T DARE USE PIPE! There is a difference between pipe and tubing...usually thickness.
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
Hottrod81
An easy mod is to weld the front and rear diffs. :greengrin:
prang11
buy a later model axle and 1.5" spacers for the front.  3" wider front and rear for maybe 200$ max.
85 Toyota Pickup, with a sweet hurst shifter!
22R, 33s, 5.29, locked rear, 3" wider, slow.
rebelKrawler83
sweet yea wat size tubing and tickness would be the best. preferably. ???
toyman2
rears up front mazda mix pack in the rear,x over hi steer,duel cases and move the stock X member
there you have a nice wheeler for less than $1000 if you do it all your self,then just read and improve from there as you can--oh and get rid of the body lift
rebelKrawler83
cool cool all of it sounds good. just gotta start workin on that money issue then it should be up and goin but right now i have to fix the engine first it messed up on me a little so yea haha :clap:
rebelKrawler83
wat do you guys think about runnin a spool in the back and something else in the front
Hottrod81
If you don't mind some chirping of the tires on the street, it will work great for you off road.
rebelKrawler83
yeah i dont really mind that im usually chirpin my back tires anyway haha. (lead foot) but yeah wat would a good spool be and how much?
Travota
85 toy
01 Silverado
toyman2
been running welded for 10 years front and rear
rebelKrawler83
yeah but if its welded in the front wat about your burfields. and idk i dont really like the sound of it cuz wat if the wleds give and break that will mess up the whole diff
rebelKrawler83
how much do spools cost????   cuz i think im just gonna throw in a spool in the back cuz i need one bad cuz i wanna start doin harder :pokinit: and with a open dif its really hard to do haha
Hottrod81
check with Marlin, I believe they have spools.  I know they sell complete 3rd members with spools.
DTB
downey sells them for 189$. I believe that they are Yukon brand. Marlin sells for the same price. So, I would imagine that they are Yukon too. You can pick up a lunch box locker for about 200$, so keep that in mind too
rebelKrawler83
Quote from: rebelKrawler83 on August 21, 2006, 05:24:02 PM
wats  a lunch box locker??
like a aussie or lock right
for a daily driver  i would say aussie   but a spool is SOLID and wont ever wear out
i would go detroit true trac in the front, not welded,  either truetrac or a aussie
btw  i have a 86 wide rear axle if your looking for one
rebelKrawler83
oh thats wat it its. yeah i like the sound of a spool. nah  my :pokinit: is good enough cant afford other crap but i do need to get wheel spacers for it cuz the back tires when i flex  rub the frame haha
see buy my wide rear axle for $100  then you only need spacers for the front,  AND you get bigger rear brakes
rebelKrawler83
ill see wat i can come up with. will it fit right in there or do i have to modifie the leaf perches and stuff.  and do you have a spool or know some one that could hook me up with one for pretty cheap cuz i cant afford to much right now
DTB
check your local 4x4 boards, craigslist, ebay, etc. for a spool.
Hottrod81
