Author Topic: Center Support Bearing Removal  (Read 1769 times)
thestoic22
  • Turtle Points: -55
  • Male Posts: 24
  • Member since May '05
  • Lisa ain't walkin!
« on: Jul 31, 2006, 08:17:16 AM »
I just wanted to give thanks for Steve at South Bay Driveline for helping me solve a irritating problem that I was having.  After lifting my '84 Extended Cab I was experiencing some "spine tingling" vibrations coming from underneath the truck.  After climbing under the truck, I found that the center support bearing was completely worn out and the rear half of the driveshaft's pinion angle sucked.  Once I discovered this, I weighed the options and found that I could either replace the center support bearing and have the same thing happen down the road, or I could cut it all out and replace it with a one piece shaft.  After doing some looking on the net, I stumbled across this article and it grabbed my attention (http://www.4x4wire.com/toyota/tech/driveshaft/).
After reading the entire article a couple of things stuck out.  This shaft was, in essence, a chevy shaft built to fit onto our Toyota trucks.  This shaft was completely ready to go and outfitted with Dana/Spicer u-joints which means they are strong, as well as easy and cheap to replace if needed.  I was sold, so I contacted Steve and all he required was the flange-to-flange measurements in order to get the shaft built.  I provided him with these numbers and he custom built and shipped the shaft the same day.  When I recieved the shaft, it was noticably lighter and beefier, so I put it in and haven't looked back.   :bowdown:
I just thought I would give Steve some "props" since he treated me really well and the price was more than reasonable.  That's just my  :twocents:
And......That's it.....
Rotten
  • Turtle Points: 34
  • Male Posts: 17
  • Member since Feb '05
  • Chicks Dig Body Damage
Re: Center Support Bearing Removal
« Reply #1 on: Sep 19, 2006, 08:25:49 PM »
did you have to modify the flanges?how many $'s ? has anyone else tried a 1 piece rear shaft? or figured out a better center support than factory?
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« Reply #2 on: Sep 19, 2006, 11:27:33 PM »
I had to have a new reart shaft made for my '91 excab, had Driveline Services of Sacramento do it, turned out really well.  I took them my old 2 peice, and they used all the toy stuff and retubed it.  Cost $228, but I think it was well worth it.  They used 3 1/2 tubing, and the cost was mostly material, only $67 for the welding.
              -Ronald Reagan
Wermz84
  • Rock Nerd!
  • Turtle Points: 921
  • Male Posts: 3,518
  • Ouch My Eye!
« Reply #3 on: Sep 20, 2006, 09:34:04 AM »
I did the same thing from the same company, on my Extra cab 84.   I was having a horrible clunk noise and sometimes vibrations.   turns out it was the U-joint in the front that was busted.  I went through the same dilemma and came to the same conclusion.   Called South Bay up gave them my measurements, picked up my one piece drive line the next day and bolted it right in.  Smooth, quite, better response that the stock multi-link stuff.  And I asked him to use the spicer joints.   That was three years ago now with out any problems, never hit it on any rocks either.
Haven't looked back either.   :thumbs:
It was quite a thrill driving over highway 17 on just my front drive line.    :talkingn:
I like to Drive!
thestoic22 [OP]
  • Male Posts: 24
« Reply #4 on: Sep 25, 2006, 07:45:29 AM »
I think that it ended up being about $350 including shipping.  It was well worth the investment because mine was also put together with Spicer joints.  He custom built the shaft with Toyota flanges so it's basically a Chevy driveshaft with Toyota ends.  Not to mention the shaft has about 6" of slip extended and 1.5" of slip compressed.  All I had to do is pony up the $ and bolt it on.  He even shipped it with new longer bolts to use.  I am still driving it and I am still impressed.
Last post Oct 04, 2005, 11:00:26 PM
by SQUIRREL MONSTER
Last post Jan 02, 2007, 09:10:21 PM
by Neoworm
Last post Apr 12, 2009, 02:52:02 AM
by jimbo74
Last post Feb 10, 2010, 04:27:18 PM
by ballzdeep4x4808
Last post Jun 16, 2012, 11:43:41 PM
by dylan_doomsday
