163,518:1 Crawl Ratio - Decuple Transfercase System
Started by BigMike, June 10, 2006, 10:02:14 PM
46&2
Damn I'd need at least one carrier bearing in the front driveline...  :gap:
GNasty 82
I think at this point it would be best to ditch the standard shifter handles and build an electro-mechanical shifter system with a bunch of switches on the dash.  You could take it a step further and just put a dial on the dash and just dial in the gear ratio you wanted, and with a little bit of circuitry, it would automatically shift the correct boxes to achieve the desired ratio.
OK, so this solves the one man shifting problem, who has the solution to the mounting problem?
BTW, I don't think a 22R/E has enough torque to actually turn all those gears  :rofl2:
82 Toyota SR5 Pickup
  Marlin Dual Ultimate
  Front 5.29 LC HP Elocker
  Rear 5.29 Grizzly Locker
  BFG 37" KM2s
  Custom rear frame and flatbed
  Propane Powered.
Build Thread:
http://board.marlincrawler.com/index.php?topic=64521.0
Quote from: Toymin8r on July 19, 2010, 02:18:05 PM
"The two enemies of the people are criminals and government, so let us tie the second down with the chains of the Constitution so the second will not become the legalized version of the first."-Thomas Jefferson
Yota-Freak
jimmer009
So Mike if you drive in the opposite direction the the earth is turning do you think you can stop the earth's rotation with that thing?
Early
#37
throw some rotated adapters on the monster, could be art.
1994  4Runner w/ full doors
My hands are dirty cause i drive a yota
BoG-ToY
see I have always wondered why these people running there uber lifted and stretched trucks dont use a divorced case mounted in the middle of the chassis and lowered a bit, NOW I KNOW WHY, they are just saving up money to build one of these :bling:
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
Here is what this would be if they were all 4.70:1 boxes:
109,908,516.76:1 That is a 109.9 million to one Crawl Ratio. :ack:
GNasty 82
Quote from: BigMike on August 25, 2010, 07:37:03 AM
Yup, just in case you needed the torque and pulling power to pull a fully loaded oil tanker out of the water with a 22R/E.    :rofl2: :rofl:
  BFG 37" KM2s
  Propane Powered.
Build Thread:
:funny:
Peak torque output of a 22R-E is 137 ft-lbs, so that would be 15 trillion pound-feet of torque at the end of the axle shaft, which of course would never happen :yupyup:
SCyotacrawler420
whats the point of having 9 transfer cases? or what would you put it in... a school bus? i think you should get 9  :turtle: points for that setup an maybe go  :beerchug: after all that
mtm
hilux 82 with mk3 2.4d engine. bobed 18 inches, full soft top, 9 inches of lift,exo cage,swing out tyre carrier, front tube winchbumper with x9, rock sliders, rear tube bumper, front truetrac and rear arb lockers, twin trans adapter with 4.7 crawler gears,20 forward and 4 reverse gears, 38 inch super swampers , rear disc brake conversion, trans disc parking brake, 5.29 r&p ,rear bench seat,hand throtle,custom storage boxes, custom made snorkel,onboard air compressor,cb twin bateries,split charge system, diff guards, low profile gearbox mo
Dr.Maxwe001
 :screwy: I should have known that "mad sientist bigmike" would come up with something like this  :turtle: :turtle: :turtle:
[img]http://bo
Russell_G
put it in a custom cab and use it as a shop truck!!!
87 longbed bobbed 12inches, locked,geared,Tacoma dash, 3rz swap Its a never ending project.
My build
http://board.marlincrawler.com/index.php?topic=58589.0
GreenYoterKrawler
Another productive day at the office i see  :willynilly:  Can i have a case PLZZZZ, come on help the poor college student out Haha...
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
Cobbtunedsti
Yes.. I'd run it to!!!! There are like 100 gears to choose from!!! But on a serious note... Mike why don't you put this in a truck?? Or maybe just 5 case w/ 4.7's??? You guys own the place why not?????
*** YELLER ***
did we ever find out what this was for
:driving: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle: :turtle:      :beer:
except BACON
The most we've done and wheeled with is Triple 4.70:1 cases in the Crawler Truck. It was 2,159:1.... and was a bit on the ridiculous side :rofl:
Tofudude
Finally found an acceptable donor rig :gap:
Thats a sick truck
Sent from the HO KID network using Tapatalk 2
H8PVMNT
#55
I can't even fathom the reality of this. The numbers aren't even a decent way to measure this setup. You could let this idle in gear and still grow vines up the side of the vehicle. That's like a warp crawl...
– Steve McQueen
Talk about traction control.
emsvitil
How long would it take to take up the slack in the gears?
:dunno:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
BoG-ToY
honestly thats a good question. even in high range, how much slack would there be?
if you ran a 250 weight oil in all of the cases in low range, how much power would it take to spin it, how bout in high range?
It would be a lot of backlash for sure :yupyup:
"Wrap Crawl" ... I LIKE THIS!!
