163,518:1 Crawl Ratio - Decuple Transfercase System
Started by BigMike, June 10, 2006, 10:02:14 PM
TimberlineBryce
I think by the time the torque reached the rear tcase it would be so great that it woul snap the input shaft I you ran over a twig!! ??
See you at the Timberline!
66cobra
it's not me, it's you
Steve-44
Hey BigMike, how 'bout you do this again but use all R10 adapters!  hahahaha
BoG-ToY
r10's and 4.7s, and see how much torque you can put on the output shaft without the input shaft spinning with them all in low
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
If they were all 4.70:1 Units, it would yield a 109,908,517:1 Crawl ratio. Yes, 110 million-to-one :driving: :driving: :turtle:
Quote from: Steve-44 on April 12, 2013, 10:15:44 AM
Ha! 90-degrees of rotation :yupyup: We may have trouble keeping oil from leaking out all the shifters
hahaha mount them dry or put sealed cover plates on them.
bigdaddy76
 :bowdown: wow very impressive. I'd love to have one. But what to do with it?  :headscratch:
emsvitil
If you're in 1st low low low low low low low low low ultra-low which is moving..........
The truck
or
The earth
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Moose404
haha you guys are talking about 10 cases and i just want my single 4.7 to work! :p
Quote from: emsvitil on April 25, 2013, 06:28:57 PM
The truck
or
The earth
Let me answer your question with a question. Is Chuck Norris driving?
emsvitil
Quote from: BigMike on August 14, 2013, 07:24:21 AM
So what happens if the truck is driving one direction, and Chuck Norris is walking in a different direction?
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Quote from: emsvitil on August 14, 2013, 03:21:15 PM
absalom
Hour–Runner
AH CHEA!!!
Is it possible, and realistic to even do three??
:dunno:
If you mess it up, or break it more than a few times THATS LERNIN!!!
Steve-44
#76
Quote from: Hour–Runner on August 07, 2014, 04:53:16 AM
AH CHEA!!!
:dunno:
I personally know of three rigs that run triples:  Marlin, Big Mike, and myself.
Triples have a few disadvantages, but the advantages, at least in my case and my opinion, far outweigh the disdvantages.  (Dependant on what kind of wheeling you do)
AH CHEA!!!
:dunno:
Here is Marlin's truck with a "Triple Ultimate Overkill" (what is that?) Marlin Crawler system in 1st gear @ 1,372:1 Crawl Ratio:
And here is my truck with a "Triple Ultimate" (what is that?) Marlin Crawler system in 1st gear @ 511:1 Crawl Ratio:
Here are some videos of our trucks in action,
Marlin's truck in 11th gear @ 128:1
My truck in 1st gear @ 511:1
Also, if you are curious about Marlin's ratios, then take a look at his gear chart. Yes, his truck is a 36-speed:
Regards,
Steve-44
Since BigMike did it first, here's one of mine at GSMTR 2013.  I'm so used to it now that this almost looks fast to me.
Hour–Runner
Very nice. That is the typ of driving I like doing.  :driving:
I know this is off subject, but does anyone have or know where to get a
R151 or W56
Used or affordable clutch, pressure plate, and flywheel for a 2lte
Clutch fork, and boot for 2lte
4x4 oil pan for 2lte
Spacer that goes in between motor and tranny for 2lte
Inspection plate for bell housing 2lte
Good 2 1/2 exhaust for a Toyota surf
Well built rear bumper for second gen 4runner
V6 third locked
Thank you, have a great day!
LittleSteve
Best place for a 2lte?
i got most of your stuff...
except oil pan and spacer
i have a r150 but i dont wanna sell it (something to do with hens teeth)
u sure you dont want a g56/58? no need to adapt to rf1 then!!
also got a manual 2L pump
just a thought for your consideration,
i will check wen i get 'ome to make sure of what i have......
Refusing to fit in or comply.
Easy is not worth anything.
turbo this..
Duckie
I remember when you guys first built this years ago.  My buddies and I used to wonder how much you'd have stretch the wheel base to get that setup to work?
BoG-ToY
Quote from: Duckie on August 01, 2015, 11:08:13 AM
I am trying to figure out if the dual ultimate in my samurai is really going to be the same length as the stock samurai trans, jack shaft and tcase.
pcyc
IG: snicklephritz87
