are there winch accomodations?
I've seen you post on Pirate. Killer bender.
I think you may need more support on your exo for it to have any function other than aesthetic.
How do you like the Bend Tech? I'm learning AutoCAD 06 and Architectural Desktop, if you can do those is Bend Tech an easy move?
Some things I don’t remember seeing in the bender posts…what was the final cost, were all the parts custom or were there any “off the shelf” parts (dies, etc.)?
id suggest more triangulation can you post some pics of the bender
You spent a year designing a bender and have no experience bending tube?
Do you think its necessary to have the upper bar tucked into the truck so much? If you kept the 2 center support tubes a bit straighter they would be stronger wouldnt they?
I plan to be a mechanical engineer as well someday, but Im still a high school junior so my technical knowlegde is lacking.
damnit! I shoulda splurged for Pro instead of EZ3D Clint so Pro has EZ3D within it? I think its gonna look good, keep us posted. I gotta get back over to OFN and catch up 8)
Don't worry about buying EZ3D instead of Pro! When you upgrade, it doesn't cost any more in total than if you had bought Pro from the getgo. Talk to Cris at 2020ssi (aka fabcam on OFN) and he will hook you up with an upgrade. Yes, Pro comes with EZ2D and EZ3D built in. You can use parts interchangeably and take advantage of features from both. Definitely consider the upgrade - it is well worth it! I think you would have really liked it for doing that flatbed of yours (which turned out awesome, by the way!)
looks good is it a four runner or apickup iwouldwant to put a top camper shell thing like urs if it is indeed a pickup!!! where did u get it or did it come with it?
Looking good!! Keep up the good work. More Pics please... Just get proE wildfire. It's only like 5 to 10 grand
i would want to have a soft top bikini style top on the top of my bed where can i find one?
Started by southernyota Parts Wanted
Started by robinhood4x4 General 4WD Discussion
Started by Makohon Project Research and Build-Ups
Started by 98yota Parts Wanted
Started by BigMike Bumpers, Cages, and Tube Benders
