Author Topic: brake problems  (Read 2441 times)
norcalyoter
  • Turtle Points: 212
  • Male Posts: 516
  • Member since Jul '04
  • why be a rockstar when you can be a rock star
brake problems
« on: Apr 29, 2006, 09:05:13 PM »
My brake pedal sinks to the floor.  If I pump the brakes it holds pressure fairly well.  when I release the brake and press it again while driving, it sinks to the floor again.  I bled the Master cylinder on the sami, and bled the brakes according to the manual, and I still have the prob.  I bought a used MC and installed and still have the problem.  Unless I didn't bleed enough I'm thinking it's another bad master cylinder.... Imput?
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
Re: brake problems
« Reply #1 on: Apr 30, 2006, 01:14:46 PM »
get someone to pump and hold the pedal  when you bleed the system,  dont gravity bleed or  use one of those pesky bleeder pump things,  have somebody pump a couple times then hold the pedal dow firm while you open a bleeder on any wheel,  close bleeder and have them pump a few times and then hold down firm while you open the bleeder ,  when you open the bleeder and get nothing but fluid  then move to the next wheel
GRW
  • Male Posts: 99
  • Member since Apr '06
  • 425-903-6392
Re: brake problems
« Reply #2 on: May 04, 2006, 05:35:22 AM »
1st off think about some Speed bleeders.  :cool:
2nd Did you bench bleed the master?
3rd Sami's have any issue with the rear brakes being a peta to bleed (see 1st item, it helps).
4th make sure you adjust the rear drums as tight as you can. I try to keep my e-brake ajusted so it engages (hard) before it is 1/2 way up. Just short of dragging/slight drag is about were I like mine.
84 XTRA CAB 3RZ
01 Tundra for sale
11 TDI Sportwagon
http://www.supermotors.org/vehicles/registry/showmedia.php?id=274806
Last post Dec 06, 2004, 03:18:29 PM
by 79coyotefrg
Last post May 21, 2005, 07:43:33 AM
by Rocksurfer
Last post May 03, 2006, 01:27:48 AM
by kneedownnate
Last post Oct 14, 2006, 12:59:12 PM
by 79coyotefrg
Last post Oct 08, 2013, 08:29:39 PM
by jigz77
