brake problems
Started by norcalyoter, April 29, 2006, 09:22:20 PM
norcalyoter
My brake pedal sinks to the floor.  If I pump the brakes it holds pressure fairly well.  when I release the brake and press it again while driving, it sinks to the floor again.  I bled the Master cylinder on the sami, and bled the brakes according to the manual, and I still have the prob.  I bought a used MC and installed and still have the problem.  Unless I didn't bleed enough I'm thinking it's another bad master cylinder.... Imput?
toybuilt
You sould try unbolting your master from your brake booster and see if it is all wet with brake fluid. If thats the problem then its a bad master cylinder.
1983 Toyota Turned Chevy
RustyToy
have you used a brake bleeder... its for when you have to do it by your self. They work pretty good... has the truck bin sitting for awhile?
norcalyoter
been using the two people method
Did you bench bleed the mc?  If you put it on dry you're kinda pissin in the wind.
sblacks91
Make sure your rear brakes are adjusted, sometimes they can get far enough out to do what you are describing. (assuming the rear are drums)
