Author Topic: Front Spring Hangar  (Read 1876 times)
Zamdrang
  • Male Posts: 17
  • Member since Aug '05
Front Spring Hangar
« on: Apr 26, 2006, 07:50:33 PM »
I always thought the frong spring hangar that Marlin and everyone sells was for doing a SAS.   But I see they sell it with the 79-85 kits too....whats the deal?  Stronger? Longer Springs?  I thought you just used the stock hangars on these trucks.  :dunno:  :confused:
85 4Runner, 4.88s, 33" MTs, ARB, LC(Cam, TB, Injectors, Header), Brake Swap, 89 rear axle, SuperJunk 4" springs for now....
FIREBALL
  • Turtle Points: 190
  • Member since Feb '03
  • Hi Ho Marlin....u talkin to me
Re: Front Spring Hangar
« Reply #1 on: Apr 26, 2006, 08:37:44 PM »
Longer springs=more flex!! and putting all the extra length to the back doesn't really give you what you're looking for, that's why the relocated hangers.
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #2 on: Apr 26, 2006, 08:39:36 PM »
Stock spring hangers aren't that strong also.  The new hanger is hella stronger.
Ramrod
  • smelling like vag and loving it
  • Turtle Points: -59
  • Male Posts: 3,600
  • Member since Jan '05
  • fully bodied & Fully getting it
« Reply #3 on: Apr 26, 2006, 09:28:34 PM »
more lift with flatter springs = more flex and better ride.
lowering the front end of the spring helps with caster angle with long shackles
crapyota
  • Turtle Points: -125
  • Male Posts: 143
  • Member since Nov '05
    • www.nw-wheelers.com
« Reply #4 on: Apr 27, 2006, 12:38:52 AM »
you also need to consider that the solid axle trucks had one hanger on each side. the spring hanger goes across the front making the load dispersed evenly across the front.
88-4runner 35 boggers,5.29s,locked in rear. finally got a sas!!!! pics at photobucket(crapyota)
checkout www.nw-wheelers.com
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #5 on: Apr 27, 2006, 09:38:14 AM »
it also helps keep those pinion angles in check
Zamdrang [OP]
  • Male Posts: 17
« Reply #6 on: Apr 28, 2006, 10:06:26 AM »
Thanks all of you for the input.   From what you all are saying, the hangar is beefier, lets you use a longer spring, and lowers the front mounting position.
Begs some more questions:
Im assuming for a given spring height(lift)...the hangar will give it more lift than than the stock mount...like ramrod said...allowing use of a flatter spring for the same amount of lift.   How much does it lower the front mount?
Also, how much longer of spring does the hangar allow you to use?   Just from looking at it it doesnt look like much.
The reason im curious about all this is that im gonna order some springs from a custom spring maker....either Alcan or Deaver.   With the hangar changing some key dimensions it sounds like it wont be as simple as ordering a stock length, 4" spring for example.
So the question is...what do I deduct on lift height to compensate for the hangar, and how much longer spring(over stock length) are we talking about?
Hope this all makes sense.... :greengrin:
Thanks again everyone.... :beerchug:
« Last Edit: Apr 28, 2006, 12:44:54 PM by Zamdrang »
« Reply #7 on: Apr 28, 2006, 12:41:53 PM »
it all depends on how and where you weld it to the frame
if directly under the radiator support  it should lower the mount about 1 1/2- 2 inches
Marlin springs :dunno:
Last post Jun 12, 2004, 01:55:16 PM
by WHITE_TRASH
Last post Apr 03, 2006, 07:43:33 PM
by IronClad
Last post Jan 23, 2009, 10:06:41 PM
by 86bobbedtoy
Last post Oct 24, 2010, 08:32:44 PM
by Nimyad
Last post Apr 26, 2011, 12:13:38 PM
by kdub0013
