Author Topic: Need a good cheap lift??? help please  (Read 2445 times)
brad091703
  • Member since Nov '05
« on: Apr 17, 2006, 01:41:31 PM »
Hello. I just picked up a 82 yota. and i saw that rought country 3inch lift.  how is this lift? i want something cheap. But how would that lift flex? Let me know guys. also if you or anyone you know is selling a cheap lift let me know.. Thanks Brad
MiniSimp
  • Outdoor Enthusiast
  • Male Posts: 5,120
  • Member since Jan '05
  • SimpsonBrothers.net
Re: Need a good cheap lift??? help please
« Reply #1 on: Apr 17, 2006, 02:33:48 PM »
It's crap.
Get this or build your own leaf packs, you won't be able to go too high without going crossover steering though.
brad091703 [OP]
« Reply #2 on: Apr 17, 2006, 02:39:24 PM »
ouch... lol i only paid 250 for the truck . i want a cheap lift then im gonna lock it front and rear. whats my best bang for my buck??   thanks for you help
MiniSimp
  • Male Posts: 5,120
« Reply #3 on: Apr 17, 2006, 02:54:54 PM »
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #4 on: Apr 17, 2006, 02:59:38 PM »
F150  2wd  or chevy S10 2wd rear springs
crapyota
  • Turtle Points: -125
  • Male Posts: 143
    • www.nw-wheelers.com
« Reply #5 on: Apr 17, 2006, 03:04:04 PM »
better look into moving the rears up front also. plent of info here just look around. rears up front and chevies or f150's or even the dreaded lift block for now lots of cheap options. bigger question is what do you want to do when you are done with the cheaap lift. any cheap lift packages such as the rough country and others are more for show then function just my :twocents: and dont forget
 :worthless:
88-4runner 35 boggers,5.29s,locked in rear. finally got a sas!!!! pics at photobucket(crapyota)
checkout www.nw-wheelers.com
MR_DIY
  • Turtle Points: -40
  • Male Posts: 595
  • Member since Sep '05
  • this is why I'm web wheelin'
« Reply #6 on: Apr 17, 2006, 03:09:18 PM »
good ain't cheap and cheap ain't good.
if you are gonna run serious enough trails to warrant lockers front and rear (which will probably require cromo' axles)  then this is not gonna be cheap.  just a warning/note
other than that... have fun learning and wheeling your new rig.  can we see pics?
I'm going yota JUST so I can buy from Marlin more.
*quote*-  goes to show that a ramp hero doesn't always have what it takes to be a trail hero as well.
brad091703 [OP]
« Reply #7 on: Apr 17, 2006, 05:27:03 PM »
Okay, Well the S-10 springs would be cool. what about the front? i just want to run some 33s and have fun...  i have a spool for the rear and a powertrax for the front. let me know
« Reply #8 on: Apr 17, 2006, 05:32:43 PM »
1st gens have a flexy suspension already,  but adding some chevy or ford leavs to the pack  is what i did  and i have about 3.5  inches of lift
i have 2 chevy's in the front  and one long in the back
« Reply #9 on: Apr 17, 2006, 05:33:15 PM »
where you located??
brad091703 [OP]
« Reply #10 on: Apr 17, 2006, 05:37:03 PM »
Im by chicago. What should use to lift the front?And i should use stock s-10 springs? or get lifted ones?
« Reply #11 on: Apr 17, 2006, 06:05:11 PM »
what i did was i got a set of 1st gen S10 rear spring,  they had  leaves,  i used the bottom 2 in the front and the top in the rear chopping the hanger ends off and putting them in the toy stock pack  so the chevies  just became add a leafs
this way i didnt have to move my hangers,   but if you use some f150  springs  they will be nice and flexy,  you want the older S10 2wd springs  or ford  85-94 2wd ,  if you use the entire ford pack it will lift it about 5 inches,  i would remove  the top leaves and just "make"  a set
Last post Sep 07, 2005, 12:28:44 PM
by miks85yota
Last post Jan 28, 2006, 11:02:43 PM
by yotatilla
Last post Mar 24, 2006, 08:45:46 AM
by hudlenutz
Last post May 25, 2006, 11:50:12 AM
by blackdiamond
Last post Dec 07, 2011, 06:16:30 PM
by Jokeass-Wheelers
